Motor used?
9 replies173 views
Does anyone know what stepper motor is used in the EAF? Is it a 28BYj-48 or NEMA 17?
5 wires: unipolar, 4 wires: bi-polar. Nema 17 is a format specification not a stepper specification.
If it's 42x42 then yes but that still doesn't say what THAT Nema 17 motor specification are like. Although if it fits most likely any NEMA 17 with adequate torque will work.
Got it, the NEMA 17 spec. just refers to the bolt spacing in the front plate, the size of the front of the housing, length can be whatever is needed for the motor specifications.
Rainer Ots avatar
Quick Google image serach for "zwo eaf teardown" found several images where the motor is visible.
For example this forum post:
https://forum.astronomie.de/threads/zwo-eaf-klackert-und-rattert.357690/
shows the motor name quite clearly - looks like "35BY48"
Of course it is quite possible that ZWO has used several motors in different incarnations of their EAF product.
Ok, so it's mounting class 48, interesting that it's geared down.
Have to say I rather agree with this comment:
"I'm laughing my head off! I buy these motors with a slightly higher gear ratio for around €10 for two. Add the Arduino clone for another €4,
add the 3D-printed housing, and I have the focuser for under €10."
Rainer Ots avatar
There is a whole opensource project doing just that (with ASCOM/INDI drivers, supporting apps, extensive documentation etc.):
https://sourceforge.net/projects/arduinoascomfocuserpro2diy/
EDIT: forgot to mention that the popular extremely cheap Gemini focuser is just a ripoff of that project.
Thanks, that will be a great resource. I'm not looking to make focuser but I am interested in making other devices that I can control via ASCOM.
Arduino stepper focuser ASCOM driver development help needed
Has anyone built a stepper based focuser using Arduino and ASCOM? I’ve completed the Hardware/Arduino side and it works great but am out of my element when it comes to creating an ASCOM driver for it. I know there’s is an ASCOM template and that comm...
Arduino stepper focuser uses stepper motors; may clarify motor specifications and applications.
Sep 21, 2025
Software and drivers needed for PDMS Feather Touch motor with Pegasus
I recently purchased the PDMS Feather Touch focus motor, which you can find at the link ( Posi Drive Motor System for the Feather Touch and Astro Physics focusers ) I also purchased the Pegasus Ultimate Power Box V3 ( Ultimate Powerbox v3 – Pegasus A...
Discusses motor system software/drivers; relevant to stepper motor identification and compatibility.
Jan 8, 2026
