Can someone help me, bought a used RASA and unsure how to connect
3 replies278 views
ScottF avatar
I bought a used RASA, and there appears to be some kind of attachment to the front that I cannot connect to(see images). My understanding is that you use the camera adapter plate and a retaining ring to screw on the front. The scope appears to have some other kind of attachment that does not allow that. Does anyone recognize this plate on the front ? I'm not sure if it is screwed on like the Celestron ring and adapter plate or if the grub screws must be removed to take the tapered ring off. I contacted the seller, and he previously used and Octopi tilt adjuster on the scope, but he says he has all the parts and doesn't know what this is as he hasn't used the scope in a while.
Any ideas? I tried gently unscrewing it, but it causes the entire complex to rotate(ie, the part on the inside of the corrector plate) and from what I understand, you aren't supposed to screw anything on too tight.
The first images shows the tapered ring that looks like it was made for a collar and grub screws( Note is has small hex screws on the front and sides). The next two show the Celestron adapter plate and retaining ring that is supposed to screw onto the front, and the third and fourth show the plate and ring together and how it is the same diameter as the strange tapered ring. The last image shows the front of the tapered ring.
I don't know how it is attached, by the hex screws or screw on, so I don't want to try anything aggressive until I understand what it is and how it attaches.
Thank you
Scott
ScottF avatar
I'm wondering if the adapter is to allow for quick camera changes? I cannot find anything that looks like this on the web though.
Josh Jones avatar
You will need to unset those set screws and loosen it and remove it to get to the stock threads under that.  Your right, the optical window you don't want to rotate.  If it did rotate, you will need to recollimate the scope once you get it off or send in to celestron to have the scope recollimated by them.  (I've done both).
ScottF avatar
I loosened the set screws in the front and it came off. I should it set up later this week and hopefully collimation is ok. Thanks for the suggestions!
Matching sensor corners with subs corners
Hi there, I have a quite significant sensor tilt issue. Hopefully, I just saw a great thread on Cloudynights revealing that the M42 adapter plate delivered with my touptek ATR2600m can be used as a tilt adapter if one add 6 M2.5 grub screws. https://...
Discusses adapter plates and retaining rings for telescope attachments.
Sep 17, 2025
Williams 71 gt with rotator back focus
I have my Williams 71 gt scope set up perfectly with back focus of 64mm.. I bought a Rotator because Williams is too cheap to have one and when I put it on it messed up all the focus, I cannot even polar align now. Has anyone had this problem? I took...
Discusses attachment/connection issues with imaging equipment setup problems.
Nov 14, 2023
SCT general optical alignment
I removed my 9.25 EDGE corrector plate retaining ring today to clean the inside edge where some fibers or lint had collected. When I did, I noticed the corrector plate is nowhere near the center of the OTA. There are four set screws that hold the cor...
Covers retaining ring removal and attachment procedures for telescopes.
9 days ago
Askar 140 APO question
Y'all, I have the Askar 400 FRA quint and it's amazing in my opinion. Looking to get a longer FL scope in a few months, but actually probably sooner, next paycheck or two if we're being honest, right? oh wait i have room on my credit card...
Different scope model; author specifically asks about Askar 140 APO triplet.
Jan 15, 2024
Strange lines in photos
I was taking pictures of M42 last night, and I noticed some strange lines on my photos. I started taking pictures with my telescope about one week ago, so I’m unsure what’s happening here. Here’s an unedited example. I just boosted the exposure to ma...
Equipment troubleshooting relevant to telescope and camera setup issues.
Feb 4, 2024
