Dual mount system on an AM3 - help with the mount
13 replies443 views
Azhar Rana avatar
Hi there. Looking for some advice on setting up a dual scope system on my AM3. To do this I need to rotate the saddle plate, which seems easy enough, but I wanted to check with the community if there are any other considerations or pitfalls I need to consider before doing the rotation.
Any advice would be greatly appreciated!
Thanks
Azhar
Bob Lockwood avatar
Hi Azhar,
To be honest I think the AM3 is a bit small for a dual setup, unless you are going to use two really small rigs. The one thing I found was getting the timing of the two cameras
exposures timed right so there is no dithering between exposures as only one setup can do the guiding. I've heard NINA can do this, but I don't use NINA. I decided too just use
my two setups and image the same object, that way each one can do its own thing as far as guiding, dithering, filter changing.
This was what I used, and you can see that it's quite big and heavy. Both setups weigh almost 70lbs, and you can see there is (3) 18lb, (1) 14lb and an 8lb counterweight needed.
This image was using this setup.  Barnard's Galaxy NGC6822 with PNG 026.1-17.6 (Bob Lockwood) - AstroBin
Hope this gives you some insight into running two setups on one mount. The dual saddle and two scopes.
I wonder if the efficiency verses cost really makes sense when considering dual rig setups. When I do the math it seems to suggest that if you just go to a larger aperture you can accomplish the same thing with less cost and complexity. I can be missing some things on this so I'd love to hear from Bob about it.
Bob Lockwood avatar
Hey Tony,
I already had the two setups and would just image two different objects over one weekend which is all the imaging I usually do each month.  The idea I had was to double up on
a single object with the short summer nights, so I thought I'd see if running two scopes on one mount would be worth the extra work. It wasn't, that's why I only used it once.
For me, I was only out one dovetail and two saddles to see if this was something I wanted to keep using.
I'll still image the same object sometimes with the short nights, but by using two setups.
Azhar Rana avatar
Thanks everyone for the comments. I've been imaging with RedCat51s on two different mounts on the same target, shooting with the Askar Color Magic Filters. Lots of fun and lots of data in a short period giving me that SHO image with an OSC.  So thought about putting them on one rig. The weight calculations for 2 RedCat51s should be fine for the AM3 apparently, and Williams Optics actually sells this as a package as well. I've reached out to the manufacturer but no reply. I have an ADM dual mount plate that should hold this size, according to the specs. Wasn't very expensive.
The dithering comment was really helpful, Bob. I'm going to be trying exactly what you described with my ASIAIRs -  I may have some unusable frames but willing to test.
The only thing I can't find online is any experience with rotating the saddle plate on the AM3. I assume you had to do that process on your setup?
Thanks
Respectful Supportive
Bob Lockwood:
Hey Tony,
Got ya, makes sense.
Bob Lockwood avatar
Azhar,
I know someone that has the AM5, but I have no idea how or if you can rotate the DEC part and have the AM3 know where it is. The AP mounts have no issue with this, you just attach the side-by-side saddle assembly to the mount like you attach a scope, but the scopes will be looking east-west, not north. You then just loosen the clutches and point the scopes north and when you power up, the mount thinks it's pointing north for polar aliening. I think for you, it will be weather you can attach everything to the AM3 and rotate it to north before you power up.
Like I said, for me it was just something to try and see if it was going to work. Will be the same for you, no big loss if it doesn't.
Clayton Ostler avatar
I can only chime from the perspective of the orginal am5, because that is what I use, but I belive saddle for am3 and am5 is similar
1. Yes you can flip the saddle mount 45 degrees, its pretty easy to do
2. The dithering thing sounds like a nightmare, I just skipped ditering when i was doing dual scopes
3. Unless you have 2 indentical scopes with 2 identical cameras I dont see how you can combined the 2 data sets, but I am not really skilled in that area
My purpose was so I could do imaging and still do visual, so I lined up the 2 scopes to point at the same things,
Then my widefield imaged/guided with the asi2600 duo while my second scope was just for visual.
Probablly not super useful to you, but the part of about swapping the saddle mount is a solid solution
AstroÅmazer avatar
Wasn't voyager designed for controlling dual scopes in a master-slave configuration? Dithering etc can be controlled by the master. I think even lum and nb data can be gathered at the same time as long as nb exposure is a multiple of lum exposure and the master does nb with dithering. I haven't used it but vaguely remember reading about it. Any voyager users here care to chime in?
AstroÅmazer avatar
Yellow is Askar SQA106 + ZWO 6200MM
Red is Askar SQA70 + ZWO 2600MM Duo
Make the Duo the master on Voyager!
Other combinations exist...
Red is 151PHQ + ZWO461
Yellow is Askar SQA 106 + ZWO 2600MM Duo
If you want to spend that kinda $$$ and love fracs...
dpcarriere avatar
I have my two 80mm setup on am AM5N. My use is a little different than most. I’m using them to optimize my color data. Both scopes are with color cameras. I get 2x color IMX571 data on the same target. That same target gets mono data from a 200mm reflector with a mono IMX571. High res mono from the reflector and color to fill in from the 80mm reflectors.
All theoretical at this moment. I’m just finishing the mechanical build.
dpcarriere avatar
My setup for dual imaging. Both are 80mm. Obviously the right is the master and the left is the slave. RouzAstro makes this sweet setup.
CS - Dale
Anthony avatar
AdamJ avatar
📷 16009.jpg16009.jpgTripple FMA180pro on AM3 no issues lol.
Advice needed for first time dual setup with SGPro
Hi everyone. I'm going to start using a dual setup. I currently use SGP and want to continue using it. I'm configuring the program, but I wanted to hear about your experience with dual setup systems and using SGPro to avoid problems and get your advi...
Dual setup advice relevant to configuring multiple scopes on mounts.
Dec 16, 2025
Any other cheaper (but still good) saddles for EQ6R
I am looking to upgrade the standard saddle of my EQ6R. Best quality seems to be the Dual Saddle Plate XL from ADM but it’s quite expensive (close to 400 eur including shipping). 📷 image.png What other solutions are out there? I found the Primaluce v...
Discusses saddle plate upgrades and compatibility for mount systems.
12 days ago
Losmandy plate on EQM-35 Pro ?
Hi AB, I want to replace my current dovetail bar with a Losmandy plate but I have never used or even seen one. Are all mount saddles compatible with them ? I can’t find anything on internet to confirm wether it will work with my EQM-35 Pro
Addresses mount saddle compatibility and dovetail bar replacement questions.
Feb 21, 2026
