Setup with 8 or 10 inch Newton?
12 replies518 views
Tobiasz avatar
Hello,
I am interested to know, if there are users who use the M-UNO in combination with a newton telescope? Especially with 10 inch aperture, f/4 and with a mono camera?
I have a 6 inch Newton and a RC10 and think about adding a 10 inch newton but I think this might be too tight. There are some images of UNOs carrying 10 inch Newts, but no more information on that.
Anyone here who made it work?  Mind sharing an picture and how you did it?
Aris Pope avatar
Get it. You will not regret it.. I have a 6", 8" and 10" Newtonians.. The difference of just 2" is enough for you to notice in framing. Bang for the buck, you won't get anything better than a 10" Imaging Newtonian. i Also recently added a 12" Meade SCT but that's a different story lol.
I had my 10" Newt riding on my trusty iOptron GEM45 for over two years until i upgraded a CEM60 a couple months ago.
Tobiasz avatar
Aris Pope:
*Thank you for your feedback, I cannot agree more with you about the advantages but we M UNO users are more limited in telescope dimensions than "normal" EQ Mount users. If the telescope is too long, we might get problems as we do not do a meridian flip.
Let me express the size limitations with an image. Thats the setup from Alexanders Reinders from the Avalon User Gallery. As you can see the telescope can hit the RA axis flange if it gets too long. But you also have to balance it, so if the setup is too front heavy and too long it will not achieve balance ever.
I see Alexanders even had to deploy some counterweights on the telescope itself, but I am missing more information on the setup. He is also using a DSLR only, so if I would deploy my mono setup the scope would be even heavier on the front.
TiffsAndAstro avatar
I think there is a Dec extension pier ?
10mm example here
https://www.teleskop-express.de/en/mounts-tripods-rings-rails-power-supply-14/mount-accessories-other-83/avalon-spacer-for-m-uno-declination-axis-10-mm-8620
Maybe use multiple or find a thicker version.
I'm not recommending this or the shop, ive never used either. I just like the design of this mount
Tobiasz avatar
TiffsAndAstro:
10mm example here
*Thanks, I am using a 50mm spacer for my RC10 already, because with the Touptek AFW L it gets too tight for my taste. To have the tube above the RA axis flange I would need many more spacers, but then I would get problems with the balance.
I would prefer knowing if balance can be achieved without spacers at first, this would assure me that I have enough headroom.
Regards
Well at least it's an option, if needed.
[deleted]
you can always move the Dec arm up by switching the big L brackets
Tobiasz avatar
[deleted] · Aug 6, 2025, 04:08 PM
What do you mean? The white/silver L brackets that hold the fork arm to the RA axis?
I know that you can move up the fork arm, but we are talking about 15-30mm here, which is not much with such a big newton. But I think the height is not the problem here, but the tube length and balance. With a front heavy setup like a Newton + Mono + Filter Wheel you have to move back the scope pretty much to be in balance. Hence my initial question.
[deleted]
Tobiasz:
with the L brackets you can move the Dec arm tens of cm up or down.
regarding a longer Newton, it can still work without any issues but you'll lose the "no flip" capability, you'd have to perform a meridian flip to avoid hitting any equipment.
here's an animated gif showing how much you can offset the Dec arm on an m-zero (6 points) - https://www.avalon-instruments.com/images/prodotti/m-zero/m-zero-equatorial-mount-6-position.gif
right now my m-zero sports a takahashi epsilon 130d which is so front heavy, I had to add a counterweight on its back to balance it.
same goes for other mounts, eq6 for example, with a Quatro 250p, needs a back counterweight to balance it.
all that said, I'm pretty sure the avalon mount will be able to carry a large Newton but will need a meridian flip and be properly balanced
[deleted]
I'm sorry I don't have the exact example to show you, but I can show you the next best thing.
see how close the focuser is to the dovetail and the black metal block on top for counter balance.
you can make it work on m-uno with a 10" as well
also, as an FYI, the m-zero is rated for 8kg payload and what you see there is 15kg payload
another winning point for avalon
Aris Pope avatar
Tobiasz:
Aris Pope:
I'm sorry for the late reply but I think if you use riser blocks that might get you the clearance you need.
Maybe something like this
https://agenaastro.com/astrodymium-2-5-riser-blocks-for-refractor-telescopes.html#ca_s_size=6385
[deleted]
Aris Pope:
as I said earlier, you don't need any risers, you just move the Dec arm up, using those white/silver L brackets and you clear the Ra axis
Aris Pope avatar
I was replying to @Tobiasz . I didn't see their comment until now, a month later as i mentioned to them. I didn't bother going through the other comments. Good on you figuring it out.
Seeking high focal length telescope recommendations for deep sky imaging
Hello, I have been using medium to lower focal lengths for a few years and wanted to get into the realm of high focal lengths for deep sky. I know that its usually more expensive then high focal length planetary, but I am willing to spend a few thous...
Author seeks telescope recommendations; post discusses Newton telescope compatibility issues.
Jan 23, 2026
Mount discussion relevant to author's equipment setup and configuration concerns.
27 days ago
10-inch Vs 8-Inch Dobsonian?
I have been looking around for telescopes for a while. Specifically, a telescope that can take nice bright photos of deep-sky objects. I have settled on the 8-inch StarSense Dobsonian from Celestron, as it is only 800 dollars and I'm on a tight b...
Directly compares 8 and 10 inch Newton telescopes, addressing author's main question.
Nov 14, 2023
Astrophotography on a Budget: My €341.12 ($399) DIY Harmonic Mount Review & PHD2 Test
V3 Mini Performance: My Results After Two Months of Testing (Solar & Deep-Sky) Hello everyone, Lately, my inbox has been flooded with questions about the performance of my V3 Mini mount. After more than two months of rigorous testing, I wanted to...
Budget-focused astrophotography mount review may help author evaluate equipment options.
Sep 11, 2025
