NB Filter Bandwidth Requirements for Galaxy Imaging - AND- Announcing the Galaxy Studio on AIC
3 replies296 views
John Hayes avatar
A question that comes up every once in a while around here is what narrow band filter to use for adding Ha to Galaxy images?  The concern is that as galaxies get further away, their light becomes more red-shifted so the question is how well will 3 nm, 6 nm, or 12 nm Ha filter bandwidths work for imaging distant galaxies.?  Next Sunday, July 13 I'll be appearing on the Astro-Imaging Channel to present an updated version of my "Galaxy Studio" talk that I gave at NEIAC.  It starts at 6:30 EDT but double check the time to be sure.  It covers a lot of aspects of galaxy imaging ranging from acquisition to processing.  Here is a slide from the talk that addresses the question of filter bandwidth requirements.  Not all galaxies are receding at the exact rate predicted by Hubble so understand that this calculation is presented in the best tradition of astronomical estimation.  The image size estimates are for galaxies with a size similar to the Milky Way (~100,000 ly).  I use 3 nm filters in my systems and in most cases, they work just fine and they are great for imaging emission nebula when the moon is up and the sky is bright.  I've used 5 nm Astrodon filters as well and they seemed to work quite well.  In generally, I would recommend either 3 nm or 6 nm filters for galaxy imaging.  You'll save money with 12 nm filters but you'll also loose a fair amount of contrast when the moon is out.
Hopefully this is helpful and I hope to see a lot of you next Sunday on the channel!
Dan_I avatar
For distant galaxies around 300 million l.y. away, the H-alpha line sits within the bandwith of an SII filter so there's room for interesting experiments, for instance with Stephan's quintet.
Rostokko avatar
Interesting; I wonder if that's why I got nothing on NGC 5754 (~220 million light years) when I used a 3nm Ha filter. I suppose I should try using the Sii 6nm filter I typically use with Hyperstar to see if it catches anything.
John Hayes avatar
Thanks…that’s a good point Dan.  The challenge at that distance is that the galaxies don’t subtend much size on the sensor so it’s more difficult to distinctly resolve the small Ha regions.  Of course it should work well if there’s a large Ha cloud at that distance.
TAIC: The Physics of Dew Prevention coming up Sunday, 9/7/25
On this coming Sunday, September 7th, I’ll be back on the Astro-Imaging Channel to talk about “The Physics of Dew Prevention”. This is a new and improved version of the talk that I presented at NEAIC last spring. Here’s a brief description: It seems ...
Different Astro-Imaging Channel presentation; author appears as regular speaker there.
Sep 5, 2025
Filter question ...
Filter question: I have an astronomik h-alpha 12 nm filter for use with my (unmodified) canon 70d dslr camera. Will this work with my asiair mini? or will everything be so dark that the guide camera wont be able to see enough stars for polar aligning...
Narrowband filter bandwidth requirements relevant to your H-alpha filter application.
Sep 30, 2023
