Best rig for beginner (suitable to Sky-Watcher AZ-GTi in equatorial mode)
14 replies407 views
Carlos Rios avatar
Hi i have the az-gti eq mode and i have a 102-1300 maksutov, but now i want a deep sky telescope, i know the mount can only have  5kg weight, some recomendations?
Wonderweb avatar
Hi Carlos
Alot depends on your budget. Something like a Redcat 51, a sharpstar 61 or a SW evostar 72 ed depending on what you want to spend woukd be ideal, along with a 533mc camera.
jratino avatar
I would say something in 60mm range. I used a William Optics Z61 for over a year with it. And easily got five minutes subs with it. There's quite a few options in that range.
astronomythecus avatar
I'm using an Askar 71F along with IMX585 and performs pretty well
Oliver Hext avatar
I have a Redcat 51mm on an AZ-GTI mount in EQ mode.  No issues.
phistiegler avatar
I did some stuff with Az-GTi in eq mode with a Lacerta 80/500… It worked but nevertheless I would recommend a short 72mm Apo at max (the Lacerta one is a fine piece if scope in my opinion).
Wonderweb avatar
To be honest, it all comes down to your pixel scale. I had a takahashi fs60cb on my azgti with either a 585mm or 533mm giving me a pixel scale of around 2 - 2.7 arcseconds per pixel and my azgti would merrily guide to around 1 - 1.5 arcseconds per pixel so I was good for up to 5 minute exposures no problem.
If you're not looking at guiding with your rig, then, with a scope in the 250-400mm focal length range, and a camera with a pixel size of around 3-4 microns, you should be fine for 1 minute exposures unguided so long as you're polar alignment is good. You may end up throwing the odd sub away due to start trails but it shouldn't be too bad.
dummieastro avatar
Askar 65 PHQ, Askar FMA 180 pro, Redcat 51.
Oscar H. avatar
Redcat 51
Aloke Palsikar avatar
As an alternative you can also look at Askar SQA 55 f/4.8  along with any OSC such as ZWO ASI M533 MC Pro.
It is quite price competitive as compared to Redcat with same performance
AstroRBA avatar
I use this combo as a travel scope (with an ASI294MC Pro and ASI AIR) - very easy to pack and set up etc.
Elwin Afman avatar
I use a poor mans RedCat:  Evoguide50 ED for imaging (and a ZWO585MC pro), great combination and cheaper than the RedCat.
Oscar H. avatar
Elwin Afman:
OP will need to get the Starizona flattener for this one. Skywatcher FF doesn't allow the use of a filter drawer because it has only 17.5mm backfocus, if I remember correctly. Pretty sure OP would want to use a UV IR cut at least, because the 585 uses an AR window.
Helpful Insightful
Elwin Afman avatar
@oscas
Oscar H.:
Elwin Afman:
True, i use the new V3 EvoFF with the 55mm backfocus.
framoro avatar
I assume it is for deep sky astrophotography since it is on eq mode.
Considering the camera, the lens and the guiding system if you are using a DSLR you will probably need to have a lighter lens (samyang 135mm). If you want to use a telescope in the range of 60/360 ot 70/420 you may need a lighter camera.
I have tried several setups on an azgti in eq mode. I did not have problems with a Canon 6d with camera lens nor with a TSO photoline 70/420 and ASI2600. Instead, I had stability problems with the 70/420 coupled with the Canon 6d, I guess for exceeding the weight.
First Astrocamera - ToupTek ATR585M mono kit or ToupTek ATR2600C color camera?
I’m inclined to buy my first astrocamera in the next few weeks. The two options I have in mind are either the 585 mono or the 2600 color, both by ToupTek. My worry with the mono kit is that the weight of the filter wheel might be too much for my moun...
Discusses camera options; author needs lightweight deep sky telescope recommendations.
28 days ago
Round stars using a guidescope at 1000mm - possible?
Hi All, I recently bought a ZWO FF130 to supplement my great little FF65. Normally with the smaller scope I’ve been getting good guiding with the ZWO 30F4/ASI120mm combo of between 0.5”—0.8” RMS. This is all sitting on an AM5N/TC40 (with weights in t...
Addresses guiding with smaller scopes; relevant to author's weight-constrained setup.
Feb 5, 2026
I would appreciate some general gear advice from experienced people...
Hey all, firstly this community seems excellent. A lot of people and a lot of knowledge. So, I was hoping I could get some general advice here. I’ve been very interested in space since I was a kid. The subject of Astrophotography always seemed too ou...
Seeks general gear advice; author needs specific telescope recommendations for constraints.
Jan 26, 2026
