imaging/guiding ratio value
4 replies224 views
Merco avatar
how do i understand if the imaging/guiding ratio value is good? for example i tried (via astronomy tools calculator) two possible setups the first is 1:2.18 and the other 1:1.28
are both good or should i change?
I'm not sure what you're asking here. Guiding normally runs the whole time you're taking images so I'm not sure what ratio you're talking about here.
Merco:
If you mean pixel scale ratio both will be good but I'd plump for the first as it would make fast guiding more likely, should you need to.
Médéric Hébert avatar
Like Andrea said, both are good, you want to be below the 1:5 threshold and both are.
Merco avatar
Great, thanks everyone!
(Worm Gear) Mount Advice
Recently had to do some maintenance to my EQ6-R Pro Mount due to guiding issues and thought I'd share for anyone who may be struggling with similar issues. ———— I’m using an EQ6-R Pro with an EdgeHD 8, OAG, and ASI2600MM. Mount is about 2 years old a...
Discusses mount guiding issues; relevant to understanding guiding ratio optimization.
Dec 16, 2025
