Pete Carpenter avatar
Hello,
I was wondering if anyone has achieved a successful motor controller update on an EQ6R Pro? Skywatcher seem to have recently released the firmware loader for Mac to their website, great I thought as I have no access to a Windows machine, however when I connected the mount to my M3 Mac via the usb port and run the installer/loader it doesn't identify any connection on the usb and if I run current MC version request all I get is an error message saying it can't find a motor controller.
The instruction sheet that goes alongside the installer says to use a Synscan usb dongle but I am under the impression that if you have a usb port already then this is not required as it seems to just convert the HC port into a usb b port.
Any help greatly appreciated.
Thanks.
Tom Herbst avatar
You can maybe try to emulate a Windows Machine with VirtualBox or any other hypervisor which is available for MacOs. Normally it should be possible to bypass the USB connection from the host (your mac) to the guest system (your VM). Maybe that helps?
Going remote with an EQ6r pro
Hello everyone. I'm thinking of setting up a setup at a hosting facility 2.5 hours from home. For the moment, however, I don't want to replace my EQ6r pro, which after tuning allows me to guide at 0.3-0.6 which is more than sufficient for my ...
EQ6R Pro firmware updates relevant to author's current mount.
Feb 25, 2024
EQstar double motor system won't connect to iPhone with SynScan pro
So I own an EQstar double motor system. When I first installed it I owned Samsung phone and tablet, and I got everything to work as it should have. Now after having been ignored in the storage shed for several years, I now own an iphone, and I cannot...
EQstar motor system connection issues similar to EQ6R Pro USB identification problem.
Nov 17, 2025
