Display settings for PI, to eliminate the display quantization error.
8 replies731 views
I'm not much of a computer guy, so maybe it's not even QE, but when I'm zoomed out on an image in PI it looks like posturization error.  Zooming in and this goes away and details display nicely, but it's super annoying because I cant work on an image with a full view of the frame.
I tried a couple monitor display settings, but that didnt change it.  Is there a setting somewhere in PI or somewhere else "in the computer" that I can make this better?
Thanks,
pfile avatar
try turning on 24-bit LUTs for this image… that might solve it. in the global settings you can also just tell PI to use 24b LUTs for all images.
rob
Concise
try turning on 24-bit LUTs for this image... that might solve it. in the global settings you can also just tell PI to use 24b LUTs for all images.
rob
Hi Rob! That worked, I'm so glad I asked.  Thank you for your help.
Don’t forget to turn it on as default so you don’t have to keep clicking that.
Gleb Polyakov avatar
Ooh I didn't realize you could default to have it always on. Where in the global settings is that?
starpixels avatar
Edit menu — Preferences — Miscellaneous Image Window… “use 24 bit…”
Ah! Thank you
Mark Germani avatar
Awesome thank you! I wish preview windows used 24-bit preview as well... maybe in a future update.
CS!
Mark Germani:
CS!
Yeah, i was bummed to see that toggling that setting did not also apply to the preview window.
