az gti eq mode advice
5 replies127 views
Nikolaos Bafitis avatar
does anyone have any recommendations on how I should go about adding counterweights as I don't know what rod I should use and it's dimensions and I also don't know how heavy the counterweights should be and what model counterweights I should get, consider my setup weighs 3kg.
Wonderweb avatar
Hi.
The thread in the az gti is M12 so a piece of M12 threaded bar will work fine. Screwfix sell it. I used it in mine and clamped my counterweight in place with some M12 nuts and washers and it worked really well. My counterweight was 2.5 kg I think and that was fine for my 3.5kg rig.
they do pop up for sale 2nd hand on astro buy and sell from time to time if you want something more purpose made, but the threaded bar will get you going
CaptnCook avatar
I also use a threaded rod and I think my CW is 1kg ioptron one which I did use with a 60mm refractor for a while but mainly now use it with my camera lenses. It's given me excellent service. I saw a star adventurer GTI the other day and couldn't believe how flimsy the adjustments all were in comparison.
Hi.
Hey, how did you manage to use a 3kg rig in eq mode? Also would you recommend using 1.6kg counterweights on the rod for my rig?
Wonderweb avatar
This is my small rig on my az gti. Scope, camera, filter wheel, guidescope, focusser and asiair all came in around 3.5kg. The az gti can handle payloads of up to 5kg so i was way within it's capacity. I was getting guiding accuracy of between 0.8 and 1.4 total rms which was better than my pixel scale so it all worked out well.
what counterweight rod and counterweights did you use
Discusses counterweight setup for astronomical mounts with specific equipment guidance.
27 days ago
Fornax LighTrack II setup advice
Hello all, I bought a Fornax LighTrack II used for about 370€. It's just the tracking arm so that gave me room to improvise how I would like to have my rig set up and I've come to this final configuration. However, I am very open to any suggestions. ...
Addresses tracking arm setup and improvisation for equipment configuration needs.
Jan 10, 2026
Skywatcher quattro 10" on Sky-Watcher EQ6-R Pro. Who's doing that?
I know that with a camera, guide scope, coma corrector, focuser, adapters, etc it's close to the 20 kilo / 44 pound weight capacity limit for visual, and above the 3/4 of the capacity that you're supposed to do for astrophotography. Yet I see...
Directly addresses counterweight selection and configuration for equatorial mounts.
Feb 21, 2024
