Star shapes on Samyang 135mm
2 replies128 views
Haakon Rasmussen avatar
I have adapted the lens using the Vetec IMX571 camera. The problem is the the bad star shapes in 3 of the corners. In 1 corner it looks prolonged, another corner it has a tail. The tilt is 11 % according to ASTAP. On my EOS 6d my stars look good. I always use the lens wide open. I hope it is possible to see what the stars are like on the images. Perhaps it is a combination of the wrong working distance (not 44mm) and tilt. I have tried many different distances, but the star shapes are the worse at any other distance.  Image ist upper right corner. The other 2 corner are different, but not round.
Dan H. M. avatar
There’s a couple things going on here. The EOS 6D has 6.5 μm pixels. The pixels of the IMX 571 are about 1.7x smaller, so any issues are going to be much more apparent when using the 571. Another problem is that the lens was manufactured for use with a Canon DSLR, so the corners are going to look better out of your 6D than in an astrocamera.
These two issues notwithstanding, it’s really hard to tell if you have sensor tilt or if the lens is decentered unless you attempt tilt correction with a good device like a Photon Cage. Only by trying to adjust the problem corner can you tell if that corner is being tilted or if there’s something inherently wrong with the lens.
I will say that my Rokinon 135 shows issues with APS-C and larger, even when stepped down. My Sigma 135 behaves a lot better.
Thank you for your quick answer. I will try to do some tilt correction, and see what happens.
Weird star shape
I just bought this lens a week ago, and i am testing it out. It is good, but it has weird star shape on larger stars in every corner. Does anyone no what it is? Can anything be done with the lens, or does the search for a good lens continue? This is ...
Star shapes in corners directly matches author's weird star shape problem.
Feb 24, 2024
Do you know what is wrong with my image capture?
I've been troubleshooting my imaging on the Lobster Claw Nebula over a few sessions now. I have an artifact that I'm stumped as the the problem. 1. Collimation has been verified to be good 2. Tilt has been verified to be little or none 3. Foc...
Star shape issues in corners; troubleshooting imaging problems similar to yours.
Aug 15, 2025
Question about Wanderer ETA and multi-night registration
Hi everyone, I don’t have the WandererAstro ETA (Electronic Tilt Adjuster) yet, but I’m seriously considering it and I’ve been thinking about a possible side effect. As far as I understand, the ETA adjusts each corner of the sensor independently. Thi...
Discusses electronic tilt adjuster for multi-night registration and tilt correction.
Aug 31, 2025
ZWO T2 Tilter with MPCC iii coma corrector and DSLR
Hello guys, I got myself new equipment and i was having problems with distorted stars in the corners of the images. I suspect that i have sensor tilt since i tried all methods of collimating my scope, focuser is sturdy and looks like it is aligned pr...
Similar star distortion issue in corners; may provide troubleshooting insights for your situation.
Sep 22, 2023
RASA11 (V1) - Strange severe tilt
Over time, the performance of my RASA11 (Ver1) seems to get worse. I am still able to correct most of the optical problems with software like the BlurXterminator, but the scope needs an overhaul I guess. To demonstrate, what I mean, here a screenshot...
RASA11 tilt problems corrected with software; directly relevant to your tilt issue.
Dec 3, 2025
