Best way to add Ha data to LRGB in Pixinsight?
6 replies431 views
Andy Wray avatar
I'm new to PixInsight (one day in) and am trying to add Ha data to LRGB.  The way I used so far was to use Pixelmath to work out the difference between the Ha data and the Red channel and create a a sudo-starless image like below:
I then used Pixelmath to add that back on top of the red channel in the original RGB image.
I also replaced the luminance channel with the Ha image by separating out channels and using LRGB combine.
Is there a better/more logical way of doing this stuff?;  I would ultimately like to do HaOIIILRGB on the Crescent Nebula.
The result so far is:
Crescent Nebula - First attempt at HaRGB
Use the NBRGBCombination script.
Andy Wray avatar
I just tried it and ... it's a great way of doing a quick and dirty combination, but left me with some ugly stars.  I'll look at what the script is doing, because I'm sure it will give me some hints.
Weird. Never had issues with star shapes. Alternatively you could use LinearFit on the H-alpha image using the R channel as a reference and then add the two together in whatever proportion you find you prefer.
Roberto Marinoni avatar
If you have an LRGB image and want to add Ha, I would add Ha to RGB by extracting R channel from RGB and then adding Ha data to reinforce the R signal.
If you have also OIII you can do the same by extracting G and B channel from RGB and use OII to reinforce G and B signal.
You can find a good and detailed tutorial here:
https://www.lightvortexastronomy.com/tutorial-combining-lrgb-with-narrowband.html
Olly Barrett avatar
I’ve just done my first Ha LRGB image (see below) and combined the Ha to the Red channel using pixelmath inside Pixinsight, the expression used is in this excellent YouTube tutorial, once I’d combined the Ha and Red then the rest was straightforwards…
Hope that helps …
https://youtu.be/CDBejs636hk
Brent Newton avatar
Roberto Marinoni:
I second this, I use this method for all of my NB/BB combinations. However, I have also found to first run StarNet on the NB imagrey before isolating it from any interfering broadband continuum. This avoids any possible issue with stars having double contributions from each channel and makes the result cleaner
Helpful Insightful Respectful
Which formula do you recommend to recombine stars with starless nebula with PixelMath?
Hi everyone! I would like to improve more the way I use PixelMath to recombine Stars with Starless frames after being processed separately. I used to add them with a basic formula like: stars + starless But I think that maybe is the worst way to do, ...
Discusses PixelMath techniques for recombining processed frames, directly relevant to author's workflow.
Mar 9, 2023
Methods of incorporating Ha into RGB or Luminance
I came across a relatively new method of incorporating narrowband data into RGB and luminance images. Charles Hagen developed the method which he describes on his website (https://www.nightphotons.com/guides/advanced-narrowband-combination). It is da...
Directly addresses incorporating Ha narrowband data into RGB/Luminance images, core topic of post.
Jul 3, 2023
