Might This Be a Light Leak?
4 replies139 views
Jerry Gerber avatar
This streak is showing up on more than one filter, so it's not on the filters.   I've had the cover/flip-flat wiped down, so it's not coming from there.
Anyone know how to get rid of this?  Though it seems to be calibrating out, I don't see it on the lights, I'd still like to know if it's a defect in the camera or something else.  It might be on an optical component inside the scope.  Should I try and clean it?
Thanks,
Jerry
bigCatAstro avatar
I have a similar aberration that appears in my flats running roughly in a diagonal from a 1 o’clock to 7 o’clock position and it always calibrates out so I just leave it alone.  I do my best not to disturb my imaging train at all (other than taking the entire system off of my mount for storage) so it stays relatively consistent.
Well Written Concise
Photon_Collector avatar
Spider web in imaging train?
Jerry Gerber avatar
Hmm, maybe.
Telescope Mirror Cleaning
Just sharing my success with what is probably a 'cheats' way of cleaning my 8" GSO Classical Cassegrain primary & secondary mirrors. The larger size of the 8" telescope tube allowed me to get away with it. Instead of the recomme...
Telescope mirror cleaning techniques applicable to internal optical components.
Aug 10, 2025
Halo artifact troubleshooting on Esprit ED80 and lens cleaning safety
I’m looking for some troubleshooting help with my Esprit ED80. I have this strange halo artifact on mid to bright stars (see attached image). If I rotate the image train, the defect follows the scope, so I know it’s there, and it is equally present i...
Similar artifact troubleshooting approach for optical defects in imaging systems.
Nov 26, 2025
Secondary mirror coating issue or possible light leak problem?
I was considering sending my secondary for my ago idk 14.5" over to terry at ostahowski optics for a recoat because if I look closely enough, I have what looks like an oil spot or something that slightly dulled a small part of my secondary coating th...
Secondary mirror coating issues may cause similar streaks or artifacts.
Nov 3, 2025
Pacman Ha streaks
Hi all,Wondering if you can help me sort out these comb-like streaks in the Ha data I’ve collected on the Pacman.I’ve not seen these streaks on any other Pacman I’ve searched for on-line, so I am assuming it is not data but some kind of artifact. If ...
Light leak could cause streaks; author already ruled out filters and flat.
Nov 20, 2023
