Nightcrawler Rotator & NINA
11 replies312 views
Jerry Gerber avatar
I am trying to figure out how to get the 0 position in NINA's framing setup (see image) so that ZERO on NINA's rotation scale matches ZERO on the rotator.
Do I need to use the Nightcrawler software  to do this or can I do it all in NINA (preferred)?
Right now, when I use NINA's "Determine Rotation from Camera", the zero position on the rotator does not match the 0 position on the sensor boundary image in NINA nor does it match the 0-359 degree scale in NINA.
Thanks,
Jerry
The angular position in NINA is referred to the celestial coordinates so that zero is due North and 90 is due East (if I'm not mistaken). The zero on the rotator is referenced to the physical zero point of the local encoder (or stepper position for the lower end of rotators) and I assume, never having used the NC, that you have to zero-in the two.
Robin Bosshard avatar
When NINA is scheduled to rotate, it does a plate solve to determin the current rotation, calculates the difference and orders the rotator to move that difference. There should be no need to zero-in since the rotator's driver should convert the difference from degrees to mechanical steps and move accordingly what ever the current mechanical position is. If the rotator has a rotation limit set, the driver should probably move the long way round as not to exeed the limit.
I don't use NC, though…
Clear skies!
Pete Bouras avatar
I believe once you have your rotator adjusted to your preferred orientation angle, you can 'zero' the angle measurement in the nitecrawler software.
Well Written Concise
Jerry Gerber avatar
Thank you for replying.   I am still slow to grasp whether I should keep the 'REVERSE' on or off.
When I am in NINA's framing window and I get the object framed the way I want, I click on Slew, solve and rotate and expect the rotator to find the angle of rotation I specified.  I have the rotator's limits set to 180 degrees.
NINA has the Sky Position, and the Mechanical position, I understand what the difference is but not sure how they interact.
Can  I damage the rotator if it's going in the wrong direction?  I don't know which direction is correct as I am 1000 miles away from the scope and I can't turn on the light over video to see what's happening as it will disturb the other imagers in the observatory.   Whether I should rotate left or right depends upon the object I am imaging, yes?
Thanks,
Jerry
Respectful
Bill McLaughlin avatar
I have the NC on several scopes and I would never try to have it rotate at night and (worse) doing it at night unattended is just asking for trouble, IMHO. You might get away with it for a while but sooner or later it will bite you regardless of how well set up it is.
You might wrap a cable and break something and it may result in shifting things enough that flats will no longer match exactly either due to a rotational mismatch or movement of dust particles. Further than that, in some cases rotating the camera will cause balance and/or issues with your pointing and tracking model, especially with mounts like the Planewave that are balance critical.
I leave my camera in the same orientation for many months at a time and only change it when I have a list of objects requiring a different rotation and then I do it during the day while I have the daytime real-time monitor camera looking at the camera and usually have the observatory owner helping me and watching for cable issues.
IMHO,  frequent rotation is just is not worth it and leaving it where it is despite the less than ideal framing is much safer and less trouble.
Not just a NC issue but a rotator issue of any brand.
As far as NINA goes, I just set up the  image search/framing section with the same rotation numbers that I get from a plate solve so that the planning image downloaded from STSci matches my existing camera orientation so I get the right framing and position when setting up an object. That rotation is then automatically dropped into the target which results in no movement of the rotator (since it is already there).
My .02
Jerry Gerber avatar
Bill McLaughlin:
IMHO, it frequent rotation is just is not worth it and leaving it where it is despite the less than ideal framing is much safer and less trouble.
My .02
Hi Bill,
How do you know how to rotate it in the day if a given object might require a different rotation than another?  It seems like it has to be done at night when the scope has been slewed and plate solved on that object.
I only rotate once as I always shoot only one target at a time.  So if it takes me 5 nights to image something, I only need to get the rotator right on the first night and then I leave it alone, including for all flats.
I'll check with Greg tomorrow and see if there's anything amiss.
Jerry
Jerry Gerber:
You should be able to use the planning part of NINA to do that but that will take some experimentation to know which direction to go and how far.
I typically limit my images to the two cardinal (90 degrees different) orientations, switching about every 6 months so that it takes two years to cycle thru the combinations (Jan-June at 0, Jan- June at 90, June-Dec at 0 and June-Dec at 90) which simplifies that a lot since it is basically just 90 degrees one way or the other and which way you rotate does not matter.
If I was going to do to a non-cardinal position, I would do that in the daytime using the native NC software instead of NINA and then confirm that at night.
I am sure the are some folks that auto rotate all the time but my experience with trying that has not been pleasant.
Jerry Gerber avatar
Remote imaging  can be exciting, a lot fun and enjoyable, yet it's also like driving a car at night on a windy road with my eyes closed…smile
Jerry Gerber:
Remote imaging  can be exciting, a lot fun and enjoyable, yet it's also like driving a car at night on a windy road with my eyes closed...
You are not wrong!  OTOH, once the system is tweaked it can be really very reliable.
I am probably tempting Murphy to say this  but the only equipment issues I have had in the last 6 months was the battery on my UPS dying of old age.
Ron Crouch avatar
Sorry that this is not specifically about the NightCrawler but more about rotators in general and conventions.
I am currently in the process of configuring an old TMB 80 to use an also old Falcon Rotator. It is important to understand ASCOM definitions about position angle. 0 is north and 90 is a CCW rotation of camera as viewed from the back looking at the sky. Continue with CCW rotations past 180, 270 etc. Now the KEY part! With rotation set as above and a one time plate solve to find 0 reference the rotator mechanical angle to also be 0 but this is true ONLY with scope pointing to the east, pierside = west!! So do the reference setup pointing east. To keep everything simple if using OAG rotate to 0 and calibrate PHD2 also with pierside = west (pointing to star east of meridian).
With referencing done by the book this way reverse direction is OFF in the Pegasus firmware, NINA, and also in PHD2 advanced with PHD2 connected to rotator.
I am sure most already realize that once properly referenced the situation pointing east where mechanical angle = position angle the position angle pointing west will be 180 different from same mechanical position pointing east.
The Pegasus has semi-clever firmware to change direction of rotation in two segments to suppress cable wrap. A key thing I found to avoid surprises is to actually do the mechanical angle reference in the pegasus driver at an angle at or near 0. If you define reference at some place else remove cables from all rotating parts and move rotator to 0. Then move to various angles and decide how to position the moving cables.
NINA and TargetScheduler do a fine job but there remains the annoyance that even if using a cardinal angle of 0 or 90 it insists on a 180 rotation at meridian flip. Maybe the “0/90” limit on rotation range will prevent that but is it a pity the documentation is so lacking.
Sorry for the long-winded post here but a final word relating to a rotator is that a 2” slide-in nose piece may not be precise enough so that optical center is true. Use threaded connections for the entire optical train if possible.
Ron
Rick Krejci avatar
Ron Crouch · Nov 9, 2025, 06:26 PM
Ron
I never rotate after a meridian flip with Nina. My rotator doesn’t move once set for the night’s session (or multiple nights).
My Wandererastro rotator is 100% reliable when set to 0-180 range when doing a slew-center-rotate. My Nitecrawler is also set 0-180, but can sometimes do some wonky things, and is exceptionally slow, but more accurate
Finding the Dolphin Head RA and Dec Center to export to NINA
I am trying to frame the Dolphin Head Nebula. I am not able to see how to frame it in Telescopious or NINA. I see the bright star but no outline of the nebula. I have an Askar 500 so will have a 500mm FOV. Any suggestions on rotation and coordinates....
NINA framing and rotation setup directly relevant to author's framing problem.
Dec 25, 2023
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
Addresses rotation alignment issues in NINA imaging setup.
Oct 28, 2025
