PixInsight -- separate flats for different filters?
6 replies186 views
Andy Wray avatar
I tried PixInsight for the first time tonight for stacking and was quite impressed.  I was using the WeightedBatchProcessing script and really liked the way that it automatically split all my subs by filter and created master stacked images by filter (all star-aligned) in one go smile  I was surprised, however, that it insisted on separate flat frames by filter.  I managed to fudge that by copying my flats into separate sub-directories.
My question is:  Do any of you take separate flats for each filter?  I can see the logic in it, but haven't seen much mention of it online.
Greg Meyer MD avatar
yes, separate flats. Each filter has it's own particular dust marks, and irregularities that should be subtracted from the subs.
Separate flats for all filters is a must, as other posters have remarked. Not so much for different dust pattern in each (which should be way out of focus) but for the difference irradiance each filter have. And vignetting.
AstroDivers avatar
Absolutely! I do it every night on whatever filter I plan to use.
Each filter will need likely also a different intensity of the light or exposure time!smile
Adel Kildeev avatar
Totally agreed, different flats for each filter every time, it is time consuming but necessary evil.
Minh Lết avatar
I am surprised that you get by with taking one flat and applying to all the frame. Especially narrowband flat and broadband flat can have really big differences in vignetting, sensor response.
Andy Wray avatar
Thank you all.  It makes total sense to me to need separate flats for each filter.  It's just that I've only just got into narrowband and have only had  one night of imaging with a mono camera (see below)
I've also only used DSS so far and it has no warnings about the flat mismatch with filters.
It's not really an issue going forwards as flats are really quick and I can modify my flat routine in APT.
Thanks again all  ... good advice as always.
Respectful Supportive
Help with flats frames on asi 1600mm pro + 200mm f2.8
Hello everyone,I have several problems to be able to make the flats frames in the HA and SII filters im my setup (canon 200mm f2.8@f2.8, asi 1600mm-pro, filters optolong). I'm trying to use all possible types of ADU, but the image only gets worse...
PixInsight -- separate flats for different filters? — Addresses filter-specific flat frame processing techniques.
Jul 5, 2020
Diagonal banding on image
Last night was my first night with my new Vixen SD81S II and I was very excited that it was meant to be clear all night. Of course, it wasn't clear all night and actually started raining at 4am (thanks rain alarm app!). As a result, I only manage...
Not relevant — discusses banding issues, not flat frame handling.
Mar 28, 2023
WBPP not giving me my total integration time or subs used for my file, when splitting my DSLR OSC data into RGB channels to integrate
Question for any long time Pixinsight users. I've been using the app for a few months now. I have not been doing my initial stacking in WBPP, I use Siril. One reason for this is I don't guide, I have an older LX200 mount that PHD2 just can...
Relevant — directly addresses WBPP script usage and filter splitting concerns.
Sep 1, 2023
Weird flat streaks
My last series of flats all have weird quarter circle streaks across - but only for Ha and Sii, but not for Oiii. Filters are Zwo 2" Ha, Sii and Oiii filters in 7x2" ZWO filter wheel on Asi2600mm pro cooled camera on Founder Optics Apo86 Fi...
Relevant — discusses filter-specific flat frame issues and problems.
Aug 17, 2023
