Red/Green/Blue Pixels in Master Lights??
11 replies231 views
David Ebbecke avatar
After stacking in WBPP, I discovered these color-pixel regions. Online research points to hot pixels, but I took darks with the same settings as the lights and applied cosmetic correction. They are not present in the subs, only the RGB masters.
Aside from these three regions, I don't find the problem elsewhere within the image. I ran color combination, BXT, NXT (to better delineate the region of interest), and SPCC.
Any idea what this could be and how I might correct the issue?  Thanks!
Well Written Concise Engaging
Médéric Hébert avatar
My guess is that there was some object moving while you were imaging. Especially the last one, If I had to guess, you took all your Blue, Green, Lum and Red in that order (or reverse). If you look at it, it makes a straight line.
Two things that came to me after sending the original post:
1. I used 12 dark frames to create the master. I'm wondering if I should have used more.
2. My darks are over a year old. Perhaps I need to take a new set?
-David
Médéric Hébert:
Thank you! These artifacts do appear to be in a straight line as you stated. Can you advise on a technique(s) to remove them?
David
David Ebbecke:
Médéric Hébert:
David
Sadly I can't help you there, I'm no expert and I take my data rotating between filters so I've never experience that.
Depending on which software you use to process the data, you could try to clone stamp it out (Blemish blaster from Seti Astro comes to mind).
Médéric Hébert:
David Ebbecke:
Médéric Hébert:
David
Thank you, Médéric!
David Ebbecke:
Thank you, Médéric!
I hope this helps
You're welcomed
David Ebbecke:
Médéric Hébert:
David
Assuming PI blot them out with the CloneStamp.
Christoph Nieswand avatar
These are typically remnants of asteroid traces which are not removed completely by the rejection algorithm in image integration.
You might get them suppressed by playing with the large-scale pixel rejection parameters in image integration - or remove them by clone stamping …
If you check the high-rejection pixel map, you probably see the major part of the traces, which has been removed by the rejection algorithm.
Would be nice to identify the asteroids. PI can help you with this.
Christoph Nieswand:
You might get them suppressed by playing with the large-scale pixel rejection parameters in image integration - or remove them by clone stamping ...
Thank you, Christoph!
Willem Jan Drijfhout avatar
Like others have suggested, probably not an error, just a fast moving object, likely an asteroid. I've come across this before myself.
If you are interested, it is not too difficult to find out the identity. Tycho tracker makes this a fairly straightforward process. It is what I used to identify asteroid 1998 SG36 in my image of M46. In this case it was an asteroid, but it would also identify satellites or comets.
bigCatAstro avatar
David Ebbecke:
Médéric Hébert:
David Ebbecke:
Médéric Hébert:
David
Thank you, Médéric!
Blemish Blaster from Seti Astro works really well.  During the spring, I had to correct for several light streaks that were caused by asteroids and I can't tell in the final image where they were anymore.
Help with diffraction-like spikes - blue channel only
After stacking in WBPP (HaRGB), I observe an anomaly in the blue channel only, which appears only in the most prominent stars in Orion. Initially, I let it go, but after combining channels, some further processing, and pulling the stars, I discovered...
May 28, 2025
Both posts describe color anomalies that appeared only after stacking images in WBPP, with the problems not being present in the original individual frames.
