TSRCRED-G2 spacing with your RC
2 replies60 views
Stellar Nomads avatar
Hello folks
I am using the TSRCRED-G2 without the front adapter and the spacing is exactly 82mm, here is a list of the equipment I am using:
- GSO RC 14in
- PegasusAstro Prodigy with M68-M54 adaper
- QHY600
-QHYCFW3L
- QHYQAG-L
But when I measure everything exactly per spec, here is the resulting CCDInspector says:
and the resulting stack of 300 x 8 is, here is the XISK file: https://u.pcloud.link/publink/show?code=XZEMNS5ZbRrvuB0MPQVnftEyHlEH1mN9vbYy
Olivier Constans avatar
It seems to me your collimation is not good. The stars in the differents corners seems to be defocalised and deformed. I think you have coma indicating your primary miror is not correctly set.
I did the tilt tools with Astap and look
and the abberation inspector shows your star not good in the corners
Maybe you should fine tune the collimation of the primary 1st.
Thanks for trying ASTAP, I have used it on the same image and here is my finding..interesting difference
