Kyle Cerniglia avatar
So I have been using the ASI533MC-Pro and recently got a Minicam8 for a different rig and have been running into some weird problems that appear to have flats being applied to the raw frames before processing.
For the first few nights of tweaking settings, I was using the Live Stack to manually capture raw frames (No calibration frames were applied here, stacks were not used). I then used Siril to do all my stacking using the flats, bias, and darks I took and the images looked clean.
Now that I got everything configured correctly, I resumed using my sequencer scripts for frame capture, which loads the profile I just finished setting up. But now, when images are captured and stacked in Siril, I get severe vingnetting and dust motes. If I instead stack the image without any calibration frames, it looks mostly fine (Just a bit noisier since darks aren't applied).
But at no time, have I ever used Sharpcap's internal flats tools, and I verified that even when running with scripts, all the items under the Preprocessing tab is disabled, and the settings text file generated for both methods indicate identical settings.
AstroBillUK avatar
I’m away from my rig and capture PC but when I do solar and capture flats I have a check against the option to apply the flats just captured right away to the lights taken subsequently. Have you done that without realising maybe? I personally find it immensely useful as eg the image processing tools in live stacking can be applied without magnifying the effect of either dust or vignettes, but in other situations I can see it would be the opposite of what you want.
The main issue is that I'm using a filter wheel, so I'm constantly cycling through different filters.
PixInsight WBPP - dust motes/donut still not cleaned with flats
Hello, I am still seeing dust motes/donut shaped spots even after calibrating with flats. I tried few exposures with flats but no improvement. I use dark, bias and flat calibration frames and default wbpp settings. from the attached screenshot, you c...
Dust motes/donuts with flats calibration - directly relevant to flat frame issues.
Sep 30, 2025
How to Stack Fits and Raw files in one go?
I think I screwed up, I got the ASI Air mini and had a good night of imaging getting lights and darks. Because it's easier I took the Bias Frames and Dark frames direktly with my modified canon 600D instead going via the asi air. that of course c...
ASI camera user experiencing frame processing problems with different equipment.
Sep 27, 2023
WBPP Stacking generates Black and White result from OSC Light frames
Have faced a peculiar issue during WBPP Stacking in Pixinsight for two sets of of light frames . Others seem to work fine I have a OSC ASI 533 MC Pro along with Askar SQA 55 and my recent exposures of M42 and NGC 1499 have generated a black and white...
ASI 533 MC Pro OSC stacking - same camera model, stacking workflow problems.
15 days ago
Flats adding to images instead of subtracting in PixInsight WBPP
Astro Friends, I have been imaging for about 5 years and have been successful using refractors and mono imaging. I have branched out this year and now have an SCT and mono setup. I am seeking help with my flats which seem to add themselves to my imag...
Flats adding instead of subtracting in WBPP - flat frame calibration malfunction similar to author's issue.
Jan 2, 2026
