As is generally known, the GSO RC telescope series suffers from having too short a 1ary baffle. This admit light rays from outside the field-of-view, causing large and wide faint arcs in field, with a radius of curvature comfortable larger than the sensor size. They are ugly, and (at least for me) impossible to remove in post.
However, there is a straightfiorward fix by adding an extension [or replacing) to the 1ary baffle making it longer and preventing off-axis rays from entering. Or so I thought.
I have been using my GCO RC12 for over 12 months with an "add on" baffle which removed the problem. However, a week ago I swapped my Optolong LRGB filters for an Antlia set and the ghosts have returned with a vengeance, even though this is the only thing I have changed in the optical train.
It have checked that I didn't leave off the extension to 1ary mirror baffle [not impossible for me to do!] and tried with a number of flat fields (no difference) and different telescope pointings. As expected for scattered stray light, it is worst in B and L and varies in position from field-to-field.
The simples thing for me to do would be to revert to the Optolong filters, but I would like to know why a simple filter upgrade(?) could result in such a big difference.
Has anyone else had a similar experience? Could it be that the Antlia filters all have bigger blue leaks, or more stray reflections from front surface? I find all of this had to find credible, and I know that trying to track down stray light issues can be an exercise in futility, but if anyone has had a similar experience, it would reassure me that I am not going mad.
Thanks in advance Brian
