DrNigel avatar
Hi
Below is my image of the Triangulum Galaxy taken on an unmodified NikonD5100 its about 2.5 hours total of 5min sub-exposures.
Also, does anyone have any experience of Topaz De-Noise, I download the free trial (its the image with the watermark  below) and it seems to yield an improvement with more structure in the clouds. Though I don't know if these are just artefacts from the denoise process or features that are really there
maxchess avatar
Below  my new image of M33. Much longer Integration time of nearly 4 hours brings out more detail. Still much to learn about Pixinsight. For noise reduction found the EZ_Noise script which is part of the  EZ Processing Suite Plug in for Pixinsight works really well on Linear images. So much so that this time I didn't need more noise reduction after the stretch.
M33 Triangulum Galaxy
Max
Concise Engaging
Andrew Whiter avatar
I took this image of M33 on 1st October. Unfortunately, the evening was curtailed due to clouding over and this image is only based on 50 subs, each 60 seconds.
I really need to get more data to do this justice...
I'm particularly a fan of the PhotometricColorCalibration process in PixInsight which was used for this image. Before moving to PixInsight, trying to achieve a good colour balance was little more than arbitrary and unreproducible guesswork in Photoshop.
I aim for images that remain generally understated in terms of saturation, as this feels more "natural" to me.
Andrew
Well written Insightful Respectful Concise Engaging
DrNigel avatar
Many Thanks for the tip, Andrew. After last nights excellent meeting I downloaded a trial of PixInsight. Below is my original data but now processed in PixInsight including PhotometricColourCallibration. Colour balance is still a bit off, but I can now see more detail I think. The image has a lot of red noise which I dont know is due to clouds when I took the frames or noise from the DSLR.
Nigel, the red noise you mention looks to be largely chromatic noise, which you should be able to fairly easily remove. using PixInsight, this is best done before you stretch the image in PixInsight, while the image is still linear. At this stage, I use the MultiscaleLinearTransform process to remove noise, using the process twice: once to remove chromatic noise, and again to remove regular noise (on the Lightness channel). I generally use more aggressive settings for the first step as follows to remove chromatic noise. Andrew
Helpful Insightful Respectful Concise Supportive
maxchess avatar
Nigel,
Great improvement, interesting to see how Andrews suggestion helps.
Most guides suggest a core process that starts off with DynamicCrop to get rid of edge noise caused by stacking errors etc.  Then BacgroundModeliization (ABE or DB)  that will get rid of most gradients before doing PCC, that could well get rid of your "Red Noise"
I notice you say you are new to Pixinsight, it can be daunting to learn.  The most commonly quoted Guide is "Inside Pixinsight by Keller.  Its really a reference book and unhelpfully, the best place to start it is Chapter 21, worked examples. This contains the following helpful process chart for OSC cameras (including DSLRs)
Max
DrNigel avatar
Thanks to Andrew and Max for your helpful suggestions. I'll give it a try and post the results.
This forum was such a good idea
Tim Ellison avatar
Nigel,
I'm very impressed that you only started the PixInsight trial after Monday's meeting, and are already producing good results with it. Even with the benefit of Colin's excellent week long training course, it was months before I felt moderately confident and competent about what I was doing, and I still feel I'm fairly low down on the learning curve. But getting results I quite like.
Max has mentioned the EZ Denoise script, which is an add-on to PixInsight. I've had very good experiences using it. It seems to do quite magical things with my DSLR data.  I use it for linear noise reduction, after background extraction and colour correction (which nearly always is using PCC). I just press the button and let it do what it thinks best. It produces much better results than I have managed to achieve with any of the other noise reduction methods. Which might be a reflection of my skill level with the other methods of course!
Keep up the good work!
Tim
DrNigel avatar
Thank you everyone for your support ad advice with this image, I've certainly learned a lot about PixInsight  Through a combination of the above suggestions I think I've got this as good as I can at the moment.   I think the issue with is the raw data, so next step is to get loads more subs on this target  (this time without a LP filter) to see if that helps.
maxchess avatar
Nigel
why not share a Dropbox link to your original stacked etc fts file and see what the group can do with it?
Also perhaps post image in your account with acquisition details.
Max
Concise Engaging Supportive
Tim Ellison avatar
Hi Nigel,
That new version looks quite dramatically better than the first. Well done! It's hard to see it as being from the same data I think. I can see a bit of noise still present. As you suggest, perhaps a go at acquiring some new data might be the next way forward. I echo Max's suggestions about sharing the data and technical details though.
Good work!
Tim
DrNigel avatar
Went back to the start. reviewed the individual subs and discarded the marginal & bad frames. Re-stacked in DSS and generated a 32 bit image which I then opened in Pix Insight. And did the following workflow:
  • Dynamic Crop
  • ABE
  • Background Neutralisation
  • PCC
  • Histogram Transformation
  • EZ Decon
  • EZ DeNoise
  • SCNR
  • Saturation
There's still a lot of red noise in the image which becomes more evident as you do a curves stretch.
Original 32bit Stacked image out of DSS is linked - Would love to hear from anyone able to remove the red noise
Jonathan Clark avatar
Hi
I've been using software in the Topaz AI suite for a while. What I normally do is try one and/or another, eg. DeNoise/Gigapixel and compare the result with a Hubble image to see if revealed features are artifacts or not. If you do not apply these utilities too 'strongly', in my experience, it will be OK (ie. helpful). There are some articles by Nik Szymanek in Astronomy Now (I think in the last 6 months or so) reviewing some of these utilities.
Hi Nigel
I have had a go at processing your image from the linked original data you provided.
This was processed in PixInsight then Photoshop.
The PixInsight work flow was: DynamicBackgroundExtract, BackgroundNeuralization, PhotometricColorCalibration, EZ Denoise, MultiscaleLinearTransform (further denoise), MaskedStretch, HDRMultiscaleTransform (on masked galaxy), LocalHistogramEqualization (on masked galaxy), Curves (RGB), Curves (saturation on masked galaxy), MorphologicalTransformation (reduce stars), and SCNR (remove green).
The MaskedStretch actually appeared to make the most difference for some reason. The blues were noticeably bluer and the red noise areas noticeably diminished after this step.
In Photoshop I used the CameraRaw filter to make a range of small tweaks but nothing drastic.
Your original data is not bad at all. Though I notice that there is quite a lot of spherical distortion as you move out towards the corners.
Cheers
Andrew
And here is a further version with the spherical distortion removed using Photoshop:
Cheers
Andrew
maxchess avatar
That’s a pretty large improvement on where the image started. Great work.
Max
DrNigel avatar
wow Andrew, what a difference! I am beyond impressed
Clearly I have a lot to learn in the Dark Arts smile  I have a few new tools in PixInsight to research to see if I can replicate your stunning results
I'm not  surprised about the spherical distortion as I don't use a field flattener,  though one might be now going on my list for Santa
Thanks for taking the time and effort on the image
Nige
jonathan.shinn avatar
took me a while to process, this is my M33 final result. Processed in Pixinsight, approx 180 minutes of data. Captured on an APM 107/700 with 0.75 FR on a NEQ6 Pro mount and auto guided. Camera is a CDS Pro II cooled DSLR (basically a heavily modded Canon 6700D. Capture software is EKOS.
IO really enjoyed this challenge, I am sure my processing skills can improve further but I tried some things in PI that I haven't tried before and have learnt from the process. This group is just what I need to keep motivated.
Jonathan
Tim Ellison avatar
That looks very nice Jonathan. Lots of sharp detail and colour!
Well written Respectful
Which scope for galaxy imaging? 8" f/4 Newton, RC8, or 5" Triplet?
Hi everyone, long post incoming - excuse my ramblings - after I finally moved to a place with a secluded and safe roof terrace where I have enough space to put up two rigs, I'll plan to add another rig for smaller Targets next to my CEM25P with a...
Discusses galaxy imaging equipment selection, relevant to author's astrophotography interests.
Apr 23, 2023
