Esprit 120ED with 0.77X Reducer
AstroDarksTim RayStefan Kellner
25 replies718 views
AstroDarks avatar
Looking for a solution for the backfocus issues using a Skywatcher 0.77X reducer with my Esprit 120ED. I am currently on a ZWO 294mm camera so  not an APS-C but still see elongated stars at the corners. This is with 55mm backfocus from the back of the FR (I added 0.66mm of shim to cover the filter thickness). Here is how my aberration looks like right now:
I know that Lucomatico on his YT channel said he is using 59.5mm of backfocus. Is that what everyone else is using as well?
Devesh (AstroDarks)
Tim Ray avatar
It looks like you are still to close. Keep adding shims…
Anderl avatar
hey devesh,
I used the 0.77 reducer together with an apsc sensors and only had minimal issues with the corner stars. guess I used something like 56 or 57mm.
cs
anderl
AstroDarks avatar
The stars on the right of the Image don’t look too bad at all, it’s on the left they are elongated, so are you sure this is not a bit of tilt..?
Checked the tilt and it's not too bad.
Pirate Mike avatar
It looks like you are a little too close still, and there is a bit of tilt. I suggest that you fix the tilt first and then adjust the spacing a little further out if it's still needed.
Getting your field perfectly flat can be a bit of a pain. smile
AstroDarks avatar
Update: Tried to fix the tilt and its at 16%. ASTAP says moderate tilt
When I again look at the stars in the corner, they look horrible:
This is currently exactly at 55mm backfocus with 0.6mm shim added for the filter.
Tim Ray avatar
Looking at the latest image, I still think the sensor is too close to the reducer/flattener. Please continue to add shims to at least one corner is round…
CS Tim
Stefan Kellner avatar
I got ok results with 58mm Back Focus and APS-C.  I used N.I.N.A to do the tests, see my journey here:  https://skellner.github.io/projects/Back%20Focus/
You will never get it 100% as the focuser will introduce a bit tilt as well.
With tilt, I had a similar process (different scope, different camera), see here: https://skellner.github.io/projects/IMX455Tilt/
Stefan
Will check it out!
AstroDarks avatar
I really dont know where the tilt is coming from. Below is aberration inspector run on M101 ran with the same scope but this time without the reducer. This is flattener only. As you can clearly see, there is no tilt and no issues with backfocusing as well. Stars are nice and round corner to corner.
I am goign to try 60mm backfocus next clear night and will report out the results. Thanks.
preemo avatar
Hey @AstroDarks,
I also have an Esprit 120 and ran into the same issues as you when using the reducer. I had a completely flat field with just the flattener exactly the same as you. You can def try spacing but I really do not think this is a spacing issue. I tried everything from 50-60mm without any improvement. I was equally frustrated so understand how this process is upsetting.
The reducer could be adding tilt or other aberrations in a number of different ways. I also found it increases the effects of any tilt in your imaging train. Even though you are using the specific reducer made by skywatcher for the Esprit 120, it can still not match precisely and cause these issues.
You can use the tilt plate on your camera if there is one, or purchase one to get rid of it. I would also call Skywatcher customer support as I did. They can be very helpful and at least tell you if there is a defect with the reducer. I ended up just using the flattener and returned the reducer.
Feel free to DM me and I can explain everything Skywatcher explained.
I own both the skywatcher flattener and the reducer for the 120ED and I can confirm that the reducer doesn't deliver as well as the flattener, the overall star quality is definitely a bit  lower. This is true for all my scopes, the reduced field is never as good as the flattened field. Also, the reducer makes the field more sensible to tilt overall.
I do not mind that as the overall quality is still outstanding and minor aberrations can easily be fixed in processing.  To be honest: I do not find the stars in your above photo so horrible, easy to fix with a little bxt.
Maybe you can exchange the reducer for a different one or try a Riccardi to improve it a bit. Also, you can try find out where the tilt comes from: is it really the sensor (very rare) or something else in the imaging train?
AstroDarks avatar
Hey @AstroDarks,
Sent you a DM. Thanks.
AstroDarks avatar
Stefan Kellner:
The issue is corner stars are trailing. And when I stack the image, you can see a big tail on couple of stars. I guess that's happening because I am  dithering each frame. You are right that if stars are a little eggie, BXT will fix it but the tail, I am afraid not (I did blink each frame and I cant see this tail in any of my individual frames).
Thanks for your response.
Devesh
Dirk Bausch avatar
I had the same problem last year with the Skywatcher reducer on my Esprit and eventually switched to the Riccardi reducer.
I had problems dialing in backspacing. I eventually noted that my corner stars are distorted only when using L and B filters, R and G filters were well or at least much better corrected.
In the images below, backspacing was identical.
The filters are Baader CMOS-LRGB filters.
With the Riccardi, correction was much better.
Best,
Dirk
Blue:
Red:
AstroDarks avatar
UPDATE:
Last night, I tested with 59.5 mm backfocus like several others have tried. I got considerably rounder stars at the edges. There is a moderate (17%) tilt in my system due to the reducer (eventhough everything is threaded. My flattener shows no tilt) but is this the best that the reducer could do?
I then ran BXT on this stacked image and it looks good to me. Thoughts?
Tim Ray avatar
Those examples look great. You can still play a little with shims on moving the distance.  However, it appears you are very close so the juice might not be worth the squeeze on what a small improvement it would make, if any.
I know you mention you have some tilt remaining. Is there improvement with the tilt analysis pre and post BXT?
Thanks Tim
Respectful
AstroDarks avatar
Tim Ray:
Thanks Tim
It did get a little bit better - 12% from 17%
Tim Ray avatar
Thanks for the reply on the tilt analysis. I was curious and impressed that BXT improved tilt that much…
Cheers!
AstroDarks avatar
I captured 3 hrs of Oiii last night and overall the image looks great I think. I will keep the reducer! This is after GC and BXT
Backfocus using Skywatcher Esprit 120ed Reducer/Flattener
hi, I recently purchased the reducer for my Esprit 120. After some researches i found out that a backfocus of 60mm instead of 55mm gives a flatter image. Trying out both with the Asiair, i figured out that the focuser stays in the region of 1000 with...
Esprit 120 reducer backfocus adjustment experience directly relevant to your setup.
Aug 11, 2023
BACK FOCUS ISSUE - Williams Optics FLT91
In my recent sessions with my WO-FLT91 with the Flat6AIII flattener, I have noticed that the stars in all four corners are elongated, indicative of back focus issues. I checked this in the aberration inspector process in PixInsight and I am consisten...
Back focus solutions with corrector optics; applicable to author's flattener setup.
Sep 29, 2023
