Correct orientation of QHY600PH-M
16 replies332 views
Robert Lowenthal avatar
In preparation for installing a Wanderer Astro ETA (Electronic Tilt Adjuster), I want to make sure that I have my camera oriented correctly so that the ETA software will adjust tilt correctly (and not upside down).
What is the correct orientation of the camera (i.e. serial number up and to the right or down to the left), CFW port to the left or right) when the top of the sensor, in landscape mode, is pointing up?
Thank you,
Robert
Daniel Carter avatar
I have mine setup that each corner of the sensor is poointed towards one of the motors. AsG says that you can set it up either way (with the flat edges of the sensors towards the motors or the corners pointing towards the motors). Once you get everything installed, the software can be labeled so you know which corner corresponds to which motor. I put number labels that were easy for me to read on each motor. If I recall correctly, there are numbers on each motor that can be seen when installing the camera. I used those same numbers on the outside of the motor since it was hard to see them with the camera installed. I ran Hocus Focus for a baseline and then adjusted a corner in the ASG software and then ran HF again to determine which corner changed according to HF. I updated the ASG software accordingly once I knew which number corresponded to which motor number.
I'm sure there is a better better figuring out which motor corresponds to which motor number but that's how I ran mine. I have a text file on my desktop which has the info on which motor corresponds to which corner of the sensor in case the data in the software is reset.
Daniel, it sounds like you’re using the ASG EAT device, correct? If so, that seems like a really nice system. I’ll be using a Wanderer Astro ETA, which has its own proprietary software (WandererEmpire). I’m not sure how it works, as I haven’t received it yet, but I’d like to start out with at least knowing that I have the camera oriented correctly.
Robert Lowenthal:
Sorry I saw electronic tilt adjustment and assumed the ASG Photon Cage. I didn't realize there was a new one from Wanderer Astro available. I think they are using a 3 point adjustment system instead of a 4 point adjustment. I would think having 2 of the 3 adjustment points at a corner of the sensor and the third on the long edge would make it easier to adjust. I haven't looked at their software to determine if they have the ability to label the points to align with how you have the camera sensor aligned.
For the kind of money they get for these things I'm would fully expect that ASG could answer this question.
It’s for the new Wanderer Astro Tilt Adjustment not the Photon Cage. I missed what device he had just bought in his original post. I'm sure they will have instructions available soon if they don't have it published yet.
If we take the electric tilt adjuster out of the question, can someone tell me which way is “up” on the QHY600 camera housing?
Kevin Morefield avatar
Robert Lowenthal:
Pretty sure the screw on the outer lip is the “top”
Kevin Morefield:
Robert Lowenthal:
That’s what I’m thinking as well. I think the screw you’re talking about is the desiccation port. On my camera, having the port up places the serial number up as well. And the serial number is directly over the horizontal aspect of the sensor. I’ll orient it this way and platesolve an image with the camera angle at 0 degrees. If platesolve shows rotation at 0, I’m good. If 180, it’s upside down.
Nigel A Ball avatar
Robert
Just taken a few images of my QHY600 in the Obs. Mine is the SBFL.
Originally I got installed it upside down, well 180° plate solve
To summarise, for 0° plate solve the QHYCCD logo is the 'top' in landscape mode. Also the Chrome dessicant screw is upper. EFW port is to the left.
Hope this helps :-)
Nigel
Concise
Thanks for the pics, Nigel!
I also have a SBFL, but my camera has an inverted appearance compared to yours. I’m guessing that QHYCCD changed the orientation of the housing at some point.
I believe mine is upside down. This photo is looking from the “bottom” and I think it needs to be rotated to the “top”.
I’m going to reinstall it rotated 180°, with the screw for the desiccant port facing “up”. This will put the CFW port on the right side (when looking from the back), and the serial number “up”. I’ll the plate solve and see if I get 0°.
Robert
Helpful Respectful
Nigel A Ball avatar
My pleasure Robert, glad to help :-)
Here's a photo of the 'underside' of my camera for completion
Nigel A Ball avatar
Nigel A Ball:
Nigel, do images plate solve correctly in that configuration?  If so, then I’ll leave mine set as is (which is how yours is in the above photo). I think what’s been confusing me is that my camera has one screw for the desiccant tube (adjacent to the serial number), and yours has two. Plate solving an image would tell me right away, but it’s been so cloudy here I haven’t had a chance.
Nigel A Ball avatar
Robert Lowenthal:
Nigel A Ball:
Yes, the configuration in the last image solved at 0.39° on NGC7000 last night.
Looks like you might be okay :-)
There are two holes to allow for cyclic drying of the chamber - see extract from QHY website below on 'Maintenance of QHY600'
I think that’s the newer model with the “high window”. I have the “low window” model and it only has one desiccant port.
Gradimir avatar
My 600M SBFL has the sensor top lined up to the serial no. print on the housing. It's a model from the last year, I believe. I have mounted it intuitive with filter wheel motor on the same side of serial no. like the pictures above. Therefore, my OAG in front of the filter wheel is oriented “underneath” of the sensor and not on top what would be expected just looking on the combo from the front.  I noticed this during adjustment of the OAG shadow on the sensor image, suprisingly the shadow showed up at bottom of the image.
It's a QHY general disease with the documentation and they are tons of needless things printed on this cam's, but not important staff where is the sensor top and the sensor surface position for mounting purposes. Such a pity. If you want to be sure just test on daytime and don’t forget that images are up-side-down in a lens or two mirror systems…
RCC Camera Tilt Help
Help determining what I have in the way of tilt. CameraTilt_ASTAP_FLT91_ASI294MCPro
Discusses camera orientation and electronic tilt adjustment preparation procedures.
Jul 30, 2023
A spreadsheet to convert Hocus Focus result in pratical move/turns of a manual tilt adapter plate
Hi, I recently got a wanderer astro ETA. It works great but I wanted to better understand the way it works and I asked OpenAI to prepare a spreadsheet to check what the ETA was doing and also to use old Hocus Focus results as the ETA works only for t...
Spreadsheet explains ETA mechanics and software adjustment calculations.
Jan 7, 2026
Question about Wanderer ETA and multi-night registration
Hi everyone, I don’t have the WandererAstro ETA (Electronic Tilt Adjuster) yet, but I’m seriously considering it and I’ve been thinking about a possible side effect. As far as I understand, the ETA adjusts each corner of the sensor independently. Thi...
Discusses WandererAstro ETA setup and operational considerations.
Aug 31, 2025
