Benoit SAINTOT avatar
Hello everyone.
I'm pleased to announce that I just released a new plugin for NINA:
SMART FILTERS
What does it do?
  • Smart Filters helps you define your exposure time distribution across filters (L, R, G, B, Ha, SII, OIII) based on your session goals.
  • It automatically calculates the optimal number of frames for each filter, taking into account session overheads like autofocus, meridian flip, dithering, and already acquired frames from previous nights.
  • You can also save and load custom profiles to easily plan future sessions, and presets are already available.
To help figure it out, you can magine this scenario:
  • You've already captured 3h12 of L, 2h28 of R, nothing yet for G and B, and 39 minutes of Ha on previous nights.
  • Tonight, you want to end up with 40% L and 15% Ha in your final dataset.
  • You also decided to change your sub exposure times, and you know you'll have a meridian flip, autofocus routines, and dithering during the night...
Smart Filters takes all of this into account and computes the optimal plan for you automatically.
So, don't hesitate to give it a try and leave me a comment!
Further improvements are in development:
– Automatically export the results to the Advanced Sequencer
– Scan NINA's logs to automatically extract the duration of dithers, flips, autofocuses, etc., from previous sessions to provide even more accurate estimations.
Well Written Helpful Engaging Supportive
Christian Bennich avatar
Nice, that looks great. I will give it a try
AstroCapture325 avatar
This looks very interesting. Do you have a link for documentation?
Yes !
Here is the User Guide  in 3 versions : English, French, and Spanish
SMART FILTERS USER GUIDE EN.pdf
SMART FILTERS USER GUIDE ES.pdf
SMARTS FILTERS USER GUIDE FR.pdf
Concise
You might find also some more informations on my repository, the code is of course open source :
https://github.com/latelierastro/Smart-Filters
Philippe Lemaitre avatar
Thank you, I could use this.
Christian Sartini avatar
Thank you very much for this plugin that I will try as soon as the sky gives me the opportunity.
On the other hand, I'm not sure it will meet my needs because my filters are L-PRO; UV_IRCUT, triband, HaOIII, SII-OIII.
You can of course consider that the L is your L-pro, DualBand, OIII, or whatsoever
I can also think about a version where you might give a specific name to the filters
Quickly read the user guide. I use the target scheduler plugin, but this seems like an attractive alternative when you want to collect a couple of nights of data for a specific target. I'm going to give it a try. Thanks for developing.
Jim
Respectful
[pre]An evolution that could also help would be to automatically propose exposure times in % by filters depending on the type of nebula. For example, for a dark nebula, the plugin would propose 20% HII, 40% OIII, etc.[/pre]
Yes, for sure .
For the time, you already have presets available .
These presets are explained in the user guide .
There are :
- a standard LRGB
- a LRGB "sharp", to prioritize L
-a LRGB "POP", to emphasise colors
- a standard L RGB Ha
- a couple more …
You can also make your own presets, name it and save it . Doing this, the advantage is that they will recall you sub exposure time, whereas for the factory presets, I can't guess what they will be .
If you have distributions to suggest, of course I can include them in the factory presets .
Benoit
Frank Alvaro avatar
Sounds like a very useful tool. However, I'm not seeing it in the NINA plugins repository…should it be there?
Frank Alvaro:
Sounds like a very useful tool. However, I'm not seeing it in the NINA plugins repository...should it be there?
It should be available to install in the plugin page in NINA
Can't you find it there ?
Frank Alvaro avatar
Benoit SAINTOT (AstroBen60)
Frank Alvaro:
No, it's not showing, even after I click "check for updates". I'm running NINA version 3.1 HF1
NicoAstro83 avatar
Ça va beaucoup m'aider, merci Benoit!!
Frank Alvaro:
Frank Alvaro:
Have you tried with HF2 ?
Frank Alvaro avatar
Benoit SAINTOT:
Not yet; I'll try that in a day or two.
Frank Alvaro avatar
Frank Alvaro:
Benoit SAINTOT:
OK, latest version of NINA is installed and now the Smart Filters plugin is available and has been successfully downloaded. Now I just need to play with it...
A new version is available, just a fix of minor bugs ( keywords were added inadvertently, due tu base plugin template inherited code )
Target candidate storage with ChatGPT
Here’s another experiment I’m running with ChatGPT. I search for targets based on focal length on Astrobin and I save targets I’d like to shoot as my bookmarks. Then I tell ChatGPT to save the target in my “target list”. It will keep a running list. ...
Relevant for planning multi-night imaging sessions with target storage and profiles.
Aug 26, 2025
Question about Wanderer ETA and multi-night registration
Hi everyone, I don’t have the WandererAstro ETA (Electronic Tilt Adjuster) yet, but I’m seriously considering it and I’ve been thinking about a possible side effect. As far as I understand, the ETA adjusts each corner of the sensor independently. Thi...
Relevant for multi-night astrophotography sessions requiring frame registration across nights.
Aug 31, 2025
