Dave & Telescope avatar
Hi folks,
I'm setting up a RASA 11V2 and wondering what autofcusers are working for you. Thanks in advance for your input.
Dave
Doug Summers avatar
Hi Dave, I have the V1 RASA11 and a ZWO EAF.  There are about 100 motor steps covering the CFZ in seeing of 2.0 arcsecs (5% focus tolerance, NCFZ formula).     If NCFZ is new to you, you can google New Critical Focus Zone for the formula...    I find the EAF works great, even though there is some backlash when switching directions (about 85 counts).   I prefer to focus consistently inward to conclude a focus run to avoid that, but there are other options (like just adding a pre-offset count if you are switching directions).
CS  Doug S
https://app.astrobin.com/u/dmsummers
Well Written Helpful Insightful Concise Supportive
Thanks Doug. So it looks like for the EAF you need to replace/ add on to the stock RASA focuser , a feathertouch somehow? Is that what you did?
Doug Summers avatar
yes, you need to remove the stock outer knob and then connect (via set screws) a spring like bushing to the focuser drawtube (tel side), and to the EAF motor shaft.   There's a bracket to hold the motor as well.   The procedure for this was straightforward enough (and there's instructional material that can be found on the web or in the EAF document).
Robin Livermore avatar
I have the Pegasus FocusCube Zero (for SCT) on my RASA 11 v2.  Works really well. Very similar to the EAF (I have one on another rig).  As above, there is a bit of backlash with the USFS. I use NINA and have "overshoot" set in the autofocus settings.
Miguel Noppe avatar
I have the Rasa 11 V2 and use the Celestron focus motor, works fine !
Miguel
Thanks again everyone for your input on this. I finally decided to go with a Starlight Instruments feathertouch to which I connected an Optec FTX20 stepper (image attached). It’s working great so far. 👍️
Dave
Baader high speed 6.5mm or 3.5mm
Hi. I’m just wondering which filter thickness to get between Baader High Speed 6.5mm or 3.5mm Narrow Band CMOS Optimised. Set up will be the Rasa 8 and Zwo 294mm pro camera. I know the 3.5mn are more expensive but I just want the best for this setup....
Discusses Baader filters for RASA 8; relevant for autofocuser compatibility considerations.
Sep 27, 2025
Baader >F3.4 filter on the Rasa 8
Hi. I was thinking about buying the Baader Cmos narrowband high speed filter F2 for my rasa 8. But someone is selling the Baader next grade ones F3.4. I’m just wondering if the F3.4 will work just as fine as the F2 filter on the Rasa. Thanks in advan...
Discusses Baader filters for RASA 8; relevant for autofocuser setup information.
Sep 17, 2025
