Marco Pegoraro avatar
Hello everyone, I need some advice about flats.
A few months ago, I switched to a monochrome camera with an IMX571 sensor (ToupTek ATR2600M), paired with a ToupTek filter wheel and Antlia LRGB filters. As my main telescope, I use an Askar 103 APO.
I capture everything with N.I.N.A., using the Flat Wizard, and I’ve tried making flats both with a white T-shirt over the telescope and with a light panel.
Lately, however, I’ve been experiencing a problem: the flats seem to overcorrect the lights, causing noticeable artifacts in the final master. I perform the entire stacking process using WBPP in PixInsight.
I was wondering whether the issue might be due to some incorrect setting in WBPP, or if the flats (or calibration frames in general) are not being captured properly.
For calibration, I use:
• Flats peaking at 33% of the histogram
• Flat darks with the same exposure as the flats
• Darks with the same exposure and temperature as the lights
Additionally, I was wondering if there is a way in PixInsight to correct or at least mitigate the artifacts caused by flat overcorrection.
Thanks in advance!
PS
I’m attaching screenshots of the master light, master flat, and master dark, all with STF applied, as well as a file after combining the RGB channels.
Well Written Helpful Engaging
First: Clean the dust from the camera window, because it moves between shots
Second: You either have a light leak or you have an external source of indirect light
Third: Check that gain and offset are the same between lights, darks and flats. Do not assume they are, check!
Fourth: Use Graxpert to remove the offending extra background as it can deal with far worse cases than this
Fifth: Once the master flat is flattened blot out the uncorrected dust bunnies with CloneStamp
Niels_L avatar
Im not an expert (yet) but it looks like your master flat has some dust on there and they come somewhat onto your corrected master light. Do you take flats for each filter separate? It looks like one of your filters might have dust and if you use that on all other lights (that dont have dust on the filter), I can imagine the artefact coming in your master light…  Just a thought.
CS!
Concise
blastrophoto avatar
I think Andrea nailed this. You either have dust that's moved around, a light leak that's introducing further gradients, or perhaps your camera assembly was rotated ever so slightly and now your lights don't match the flats. Frustrating to find this after much data collection. It's happened to me a couple times. There are methods to create synthetic flats if you can't capture proper flats now. For the potential light leak, electrical tape is your friend. Just tape off any place there's a connection point between your camera and the telescope. It's not the cleanest method but it works. Best of luck!
Well Written Helpful Concise Supportive
Christian Bennich avatar
I concur - light leaks are a pain….
You have to be extremely thorough, a good test for me was to do a 5-minute exposure in direct sunlight during the day. If I saw nothing in my frame - I knew I had found my leak.
The cleaning part is "easy" smile
I use "Pec Pad's" and eclipse optic cleaning fluid. That has until now worked for me.
Thank you so much, guys. I’ll try to follow all the steps you wrote and I hope to find a solution, especially because I never had these problems when I was using a color camera.
Mark Fox avatar
Unless I am missing something, did you also take bias/offset frames?  I've found that my flats overcorrect without these.
Brad Hill avatar
I would definitely start with taking bias and see if that corrects the issue. I’ve never been able to get good flat correction in WBPP without bias frames.
It seems I’ve found the problem. After disassembling and cleaning the camera, reducer, filter wheel, etc., I noticed that there were eight M2.5 holes on the front side of the filter wheel. I took eight screws and sealed the holes. I then tried taking some flat and dark frames, even under very bright light sources, and the issue seems to have disappeared. 😎
Well Written Helpful Concise Engaging Supportive
Circular artifact in WBPP processed image, suspect flat frame issue
Hi everyone, I’m seeing a circular artifact in my image after running WBPP. I used dark frames and the attached master flat. The artifact closely matches the flat frame, so I suspect it may be an issue with my flats. If that’s the case, I can reshoot...
Flat frame issue causing artifacts; similar equipment and processing workflow.
Sep 29, 2025
Calibrating Flats
Hi, Should I calibrate my flats with darks as well as flat darks or bias frames, or is it not necessary to calibrate flats with the same darks I use to calibrate lights? Thanks! Jerry
Discusses flat frame issues with monochrome camera; calibration relevant.
Jul 20, 2023
Flats adding to images instead of subtracting in PixInsight WBPP
Astro Friends, I have been imaging for about 5 years and have been successful using refractors and mono imaging. I have branched out this year and now have an SCT and mono setup. I am seeking help with my flats which seem to add themselves to my imag...
Flats overcorrecting images in WBPP; directly matches author's stated problem.
Jan 2, 2026
PixInsight WBPP - dust motes/donut still not cleaned with flats
Hello, I am still seeing dust motes/donut shaped spots even after calibrating with flats. I tried few exposures with flats but no improvement. I use dark, bias and flat calibration frames and default wbpp settings. from the attached screenshot, you c...
Flats not properly calibrating artifacts; relevant to flat correction issues.
Sep 30, 2025
Please advise regarding C8 Flats not calibrating dust motes
Hi everyone Yesterday night I imaged M63. 2600MC Pro, Celestron C8 with 0.63x reducer, OAG-L and 174MM Mini All using NINA. Flats taken with my regular Geoptik Manual Flat Panel. Lights: 85 subs, 300s, Gain 100, Offset 20, Temp -5C I took my set of F...
Flats failing to calibrate dust motes; similar flat calibration problem.
