GUIDING ALGORITM PHD FOR IOPTRON CEM120 EC2
6 replies358 views
Riccardo Civati avatar
Hi
with ioptron cem 120 double encoder, what kind of phd algorithms should I use for guiding?
riccardo
Darryl Ackerman avatar
Using the phd2 setup wizard select the option "Mount has… encoders" It will select the LowPass2 algorithm for both axis.
Concise
GalacticRAVE avatar
I get the best result with resisted switch in Dec and Hysteresis in RA. Matthias
Alex Nicholas avatar
LowPass2 is the algorithm for you for RA at least. are the encoders on both axis? if so, I'd low pass on both.
With low pass, I would DEFINITELY set your min-move to a very low number (like 0.1~0.15) and set your max duration to a lower number like 500~700.
Alex Nicholas:
I have encoders on both axes.
the pixel scale of the imaging telescope is 0.75 (1033mm focal lenght + asi 2600), the guide tube is a focal length of 240 mm with asi 120 mini
Pierre Fleurant avatar
I have a CEM70EC2. I got a lot of good info from the following YouTube video by Astro-Physics:
https://youtu.be/wCu8PKjDZ20?si=VPEVGHJGklDQzlAH
I have used the procedure for my CEM70EC2 and it worked well. Make sure to run the Guiding Assistant.
Robert Lowenthal avatar
Alex Nicholas:
Alex, wouldn’t setting MinMove numbers that low cause PhD2 to over-apply corrections? I’ve found that in anything less than excellent seeing, the mount tracks better with higher MinMove numbers and gives the encoders time to adjust tracking on their own. Otherwise PhD2 is just chasing seeing and overriding the encoders.
PHD2 Settings for iOptron HA:R43EC Mount
I recently purchased the iOptron HAE43EC mount and need to know what settings in PHD2 that others are using successfully. I am not getting good results and suspect I have PHD2 misconfigured.
PHD2 Settings for iOptron HA:R43EC Mount — discusses PHD2 guiding settings for iOptron mounts.
Nov 26, 2025
