Riccardo Civati avatar
Hi
i'm using an ioptron cem 120 with dual encoder and for the moment it doesn't seem to need the guide.
In the SGP settings i set ' direct mount guider'  to perform the dithering but  it seems that the movement occurs only on one axis.
Is there something i'm doing wrong?
riccardo
Bob Lockwood avatar
I don't use SGP but is there not a setting that lets you dither in X, Y, or both.
It only allows you to enable the direct mount guider, there are no other settings apart from the pulse duration
Bob Lockwood avatar
That sounds odd that any program would not let you dither in both directions.
Help needed for dithering with NINA!
Hello everyone! I hope everybody is doing well today. last night was a great night in my area for astrophotography so I decided to shoot the leo triplet. This time I used nina and direct guider (Since I have no guide scope!) For dithering. I set it a...
Dithering issues with mount control software similar to SGP problem.
11 days ago
Advice needed for first time dual setup with SGPro
Hi everyone. I'm going to start using a dual setup. I currently use SGP and want to continue using it. I'm configuring the program, but I wanted to hear about your experience with dual setup systems and using SGPro to avoid problems and get your advi...
Dual setup configuration with SGPro directly addresses user's setup.
Dec 16, 2025
