Combining image data with different f ratios
2 replies184 views
Peter Goodhew avatar
I'm looking for advice suggestions on how to combine data between systems with differing f ratios - in my case specifically f/1.9 with f/7.9.
For example 5 hours at f/1.9 with 10 hours at f/7.9.
Creating a single stack of all data doesn't seem to work well, so the alternative of combining a f/1.9 stack with a f/7.9 stack seems more appropriate.  The question then arises as to how much weight to apply to each stack?
Luís Ramalho avatar
Hi Peter,
Maybe this video will be helpful: https://www.youtube.com/watch?v=aRdrwrzNfbQ&t=301s
Best regards,
Luís Ramalho
Peter Goodhew:
*Assuming we're talking PI here (do we?) make a copy of each and assuming they are properly scaled and aligned then use Imageintegration with Normalization set to Additive with Scaling and Weights set as SNR. Rejection as seen fit.
Ratio between RGB and L data
Hi all Are there any “golden” rules or ways of defining how much RGB vs. L data is needed on a target?
Addresses combining different data types and technical parameters for imaging optimization.
Jul 19, 2023
