AstroDarks avatar
Ran into something odd today and could use some help figuring it out. I’ve been using PixInsight and the WBPP script for a while now without issues, but this time my darks seem to be overcorrecting my lights. After integration, there’s a noticeable dark patch exactly where the amp glow usually appears in the uncalibrated lights.
I triple-checked the FITS headers, and everything matches between the lights and darks—exposure time, gain, offset, temperature, binning, all aligned.
The patch is near the edge of the frame, so I initially thought it wouldn’t be a big deal. But it’s actually throwing off background extraction a bit, and I’d really like to get it sorted before going any further with this project. In the image I posted below, it doesn’t look too bad at first glance, but the artifact gets worse the more I stretch the data.
I’m using the default calibration settings in WBPP and don’t recall this happening before. Any thoughts?
Also this problem seems to happen with my Ha only. I captured Luminance with same 300s Darks and it turned out fine. WBPP version 2.8.4.
I have another setup at home with same camera (I have two 294mm Pro's) and it is also showing a similar behavior in Ha. The elephant's trunk nebula and the M82 is from my setup at home and the Markarian's chain is from remote observatory.
Adam Block suggested to use a pedestal value which I did and I am still getting the same result on both my setups. There are no light leaks in the master darks from both cameras.
Any help will be greatly appreciated. Posting 3 different targets from 2 different cameras (both 294mm's) at 2 different locations. This issue is recent. Never had it before.
Don't use WBPP, it's evil smile. The fact it doesn't show in the L case is because the background is so bright relative to the Ha case but that tiny difference quickly builds up when you stack. The way to manage this is ditch WBPP and check what happens when you calibrate the frames. If you can share the raw frames and the darks I can check them for you (I also have the same camera so this will be making things easier).
Concise
QHY268M correction issues with camer in pixinsight
I have had this camer for a couple of months and I have not been able to properly correct images. I am coming from a 294mm and mc and I am using 33 darks at matching temp and 33 flats at matching temp. flats are calibrated with flat darks. Images are...
WBPP dark calibration issues directly relevant to poster's processing problem.
Sep 9, 2023
Help with odd master lights after WBPP
I have some simple RGB masters of NGC891 from about a month ago that ended up with an odd gradient on the green and red channel masters. I can't see anything in the individual frames that would point to this and the darks and flats look normal. T...
WBPP Dark Calibration — dark calibration problems affect master frame quality
Dec 12, 2023
"Glow" randomly appearing in RisingCam IMX571 images
Apologies if this question has been asked (and answered) before, but I haven't found it mentioned elsewhere.I recently purchased a RisingCam (rebranded ToupCam) camera: Sony IMX571 26MP APS-C sensor, TE, OSC. I ired it up for the first time last ...
WBPP dark calibration issues relevant to dark frame collection problems.
Aug 6, 2023
Flats adding to images instead of subtracting in PixInsight WBPP
Astro Friends, I have been imaging for about 5 years and have been successful using refractors and mono imaging. I have branched out this year and now have an SCT and mono setup. I am seeking help with my flats which seem to add themselves to my imag...
WBPP script issues; flats correction problems similar to dark overcorrection.
Jan 2, 2026
WBPP Local Normalization Failed
Hi guys,I ran wbpp and over half of the lights failed during local normalization. I really don't know the reason why. I ran 'Blink' before Wbpp and the frames looked fine though I didn't zoom in to check the stars. What could be the r...
WBPP dark calibration problems might cause downstream light processing failures.
Oct 24, 2023
