Hi folks,
for a while now, the multi star guiding functionality in PHD2 is available. Currently, I am using version 2.6.10dev2. The guide scope is a SVBony 60mm/240mm guide scope with an Altair GPCam3 178M or a ZWO AI 120MM mini. All this is mounted to my EQ6-R Pro. For all of my guiding sessions since the beginning of my astro photography journey, I keep the exposure times of the guiding cam in PHD2 (as suggested) within the 2-4 second range. For a while now, I use multi star guiding and it helped a lot to smooth out the guiding graph.
But some nights ago, I realized that setting the exposure time to about 1 seconds seems to improve the smoothness of the graph significantly. I tried several nights to compare the long vs the short exposure times and always ended up with better guiding if I set the shorter one. I also wondered about the speed of the data that is building up the graph. It seems, that it is twice the speed I set as exposure time. So if I set it to two seconds, there seems to be a new calculation every second. That is weired.
Is this behavior correct? Did you experience the same? The physics doesn't change, so I will think, that the 2-4 second range is still the better way to go. But the graphs are showing (only in my case?) the better results. If it happened occasionally, I wouldn't mind it. But it happened every time since I recognized it.
Is there someone who can explain this?
I am not too concerned about it, because I can't see any difference in my subs. Maybe it is there, but I haven't recognized it, yet.
Thank you
Christian
Thank you
Christian
