Help finding source of light reflections
2 replies107 views
Christopher Ventura avatar
Any idea? It happens on long subs (>2min) and using all filters except Luminance, for some reason.
It’s a Carbonstar RC6 with a ToupTek camera, filter wheel, OAG, and a manual rotator.
Thanks in advance for your help.
I don't think we can give any help unless we get hold of flat, dark and light frames.
I got it solved. It turns out that the ToupTek EFW has a position sensor with a light that reflects on the camera bolts. A firmware update did the trick, but before discovering this I put some black tape in the bolts and that helped. Ended up removing it though
Concise
Halo artifact troubleshooting on Esprit ED80 and lens cleaning safety
I’m looking for some troubleshooting help with my Esprit ED80. I have this strange halo artifact on mid to bright stars (see attached image). If I rotate the image train, the defect follows the scope, so I know it’s there, and it is equally present i...
Halo artifacts on bright stars may relate to filter/optical issues causing artifacts.
Nov 26, 2025
UV/IR Cut vs Luminance
I’m sure this is discussed at lengths here and in the internet but still I failed to find an answer. So are the 2 doing the same thing ? Are they interchangeable? I own 2 mono camera, Touptek ATR585M with a 8 position filter wheel that have LRGBSHO f...
UV/IR Cut vs Luminance discusses filter behavior differences relevant to troubleshooting.
Feb 28, 2026
Bayer-like checkered pattern on mono subs
Hi everyone. This started happening about a week ago: I have this checkered, debayer-like pattern all around my subs, even though I’m using the ASI1600MM, which is a monochromatic camera. The pattern is gone if I zoom in or out a little bit. It’s sti...
Checkered pattern on mono subs addresses imaging artifacts similar to reported issue.
Oct 5, 2025
Issue in ASIAIR autostretch preview, or actually FITS corrupted?
Good morning everyone. For some time now, I’ve been experiencing a strange issue during acquisition with ASIAIR PRO using the ASI678MC on long exposures. The phenomenon is particularly easy to isolate and observe by acquiring dark frames, so I’m shar...
Long exposure acquisition issues with ASIAIR PRO directly relevant to long sub problems.
Aug 14, 2025
