ZWO ASIAIR Pro Shutting Off - New issue since software upgrade
7 replies261 views
Megsgallery avatar
I am having issues with my ZWO ASIAIR Pro shutting off on me during the EAF process.
I have a complete ZWO setup:  6200mm pro camera, 5 slot 2” EFW, 120mm guide camera and the EAF.  My mount is skywatcher and is powered separately through a portable battery and not the ASIAIR pro.
since the recent ASIAIR software upgrade, I can’t seem to get the ASIAIR pro to work properly.  Every time I get my location, guiding and cooling setup perfect, the entire system reboots itself during the focusing stage and this  forces me to start all over again.
I don’t have any issues using the EAF when I focus manually using the controls.  It’s only when I run the autofocus software where the system gets hung up and reboots itself.
is anyone else running into this issue?
Before the software upgrade, everything was working for me perfectly.    This is a relatively new issue.
Olaf Fritsche avatar
I have a different camera than you (ASI294MM Pro), but otherwise a very similar setup to you. For me, the ASIair Pro does not cause any problems even with the latest software. Therefore, the error is probably not in the ASIair OS.
Maybe your copy of the OS is broken? Did you make a backup before the update, which you can now import? Otherwise you need to download an image file and try it with that. You can find a guide to restore the ASIair OS here: https://astronomy-imaging-camera.com/manuals/How_to_Restore_ASIAIR_OS.pdf
Good luck!
Helpful Concise Supportive
Megsgallery avatar
Thanks.  Will try this when I have a moment.
EmuHead avatar
Wouldn't be a power issue perhaps?  Do you have things plugged into the ASIAir Pro power output ports?  Try plugging those into the battery directly if possible to troubleshoot.
Szoomer avatar
I had this exact same problem with my ASI294MC Pro after the software upgrade.  Problems during autofocus, and then the system would shut down.   It turned out to be a short in my USB cord.  The timing after the update was a coincidence.  I replaced the USB 3.0 cord and it works perfectly.
Well Written Helpful Concise
Megsgallery avatar
I ended up buying a better charger that puts out 5A instead of 2A, and it did the trick.
Michael avatar
Just chiming in.  Different camera here.  2600MM and EAF was having issues after update.  First time I've ever had an issue.  I normally re focus every 30mins and it did well for about half the night.  I ended up homing and taking some darks for the library.  Power is 100% fine in my set up, nothing powered through asiair pro.  On the next clear night I will try to see what's going on.
Megsgallery avatar
Good luck.  It was a fussy issue for me to trouble shoot.  Hopefully, it starts working for you again.  I did see they pushed another software update for me last eve.
Ideas for handling different setups - how do you deal with your equipment
Hi all of you, over the last three or four years, since I began to do astro photography. I developed a method of handling my equipment. This works for me. But before I write some lines about it, I want to explain the reason for this thread. Astro pho...
Equipment handling methods may help troubleshoot ASIAIR Pro setup issues.
Aug 27, 2023
Asiair will not save Subs
My asiair plus has been working perfectly for the last six months .. the. Suddenly last night the anomaly began… 1. The asiair refuses to save images to preview and live options…while the images were being properly rendered on the screen, they were n...
Software bugs causing system failures similar to your reboot problem.
Apr 24, 2023
ZWO EAF and Esprit120ED issues
Hi guys, Was just looking for some advice if possible please. I recently purchased the esprit 120ed. I have connected up my eaf to the esprit 120ed with the correct mount required etc and on the left side (opposite to the fine tune side) After connec...
Direct experience with ZWO EAF troubleshooting and compatibility issues.
Jun 28, 2023
