Why my mini PC randomly crashes??????????
sebaromanoandrea tasselli
28 replies404 views
sebaromano avatar
As the subject states: during astro session (taking astro images at night )  my mini PC randomly crashes. My setup is fully automated meaning that I set NINA Advance Sequence, I go to bed and when I wake up in the morning  I find my scope parked, images (and flats) saved in my external drive ... well unless I find the scope stopped pointing at the sky meaning that Windows crashed and prompting to the main screen (like it has restarted during a night). I can't stand this anymore!!!!
A few key points:
  • It is random and it doesn't happen often
  • Before each session I restart the computer to reset mempry cache (i guess)
  • Installed RAM 32Gb (I recently doubled the isze from 16 to 32 Gb hoping to fix the issue but it didn't)
  • Processor Intel(R) Core(TM) i5-7300U CPU @ 2.60GHz   2.71 GHz (it's a NUC mini PC by the way)
  • Running softwares during each session: NINA, PHD2, GSS, Allskeye (+ a custom App  for clouds  monitoring to set SAFE/UNSAFE condition in NINA  based on Allskeye image, absorbing +200mb memory)
  • This is not the case of Windows  running updates...or atleast i believe so
  • I don't have a spare mini PC to run alternativly in order to eliminate hardware potential issue from the equation
  • I have no intention to use an Asiair (no ZWO user here and I like NINA)
Does anyone have similar issues?
How to troubleshoot and pin point to the root cause?
Any other suggestions ?
Thank you!!
Seba
Médéric Hébert avatar
Here's a few suggestion:
  • Make sure windows won't update on it's own via groupe policy
  • Check C:\Windows\memory.dmp to see the crash dump if it's a BSOD
  • When you updated your ram, did you add a module or replaced it? If your original 16Gb module was faulty and you simply added another one to get to 32Gb, the issue would persist
Wish you to find and fix your issue quickly
Swap the old memory with the new (you don't need 32 GB to run those softwares). Also, replace SSD if you have one spare (clone the old one first if you must but better re-install everything from scratch). Pause Win updates,
sebaromano avatar
Médéric Hébert:
Thank you for the inputs.
My comments in order:
  • I went in Group Policy Editor and WIndows Update shows "Not Configured". Should I set it "Disabled" ?
  • I can't find memory.dmp in that folder (even if I unhide all files)
  • I had 2x 8Mb cards and replaced with 2x 16Mb (like I mentioned, I had the issue before and after)
sebaromano avatar
Grazie Andrea. I don't have a spare SSD but I will consider to buy a new one if that will become last resource.
Regarding the RAM see previous reply above.
Then changing to a new SSD can be reasonable proposition. I had a similar issue with a DELL Precision and after all was said and done replacing the SSD did the trick. At any rate it isn't the windows update since this can be forewarned (occurs every fortnight) and is not random.
sebaromano avatar
I will start  looking for a compatible SSD replacement. I hate the idea to reinstall everything but it's for a good cause, assuming that it will fix it smile
It's been a while since I did it, but I think disabled is correct
No memory.dmp means it probably wasn't a BSOD (or it was severe enough that it couldn't generate it)
Doesn't sounds like a ram issue then
sebaromano avatar
I failed to mention that I do also connect an external (portable ) HD drive for saving the images during the session. Should I first  try to run the session  without connecting that HD potable drive?
It is always best to avoid that as the USB might not be completely reliable but I have yet to hear that being a cause of a crash. The only other thing to check is whether you run the rig without any leakage to earth, in other words your impedance when everything is attached (but not powered!)  should be of the order of the MOhms.
sebaromano avatar
Do you mean if my gear is electrally ground connected? Because it is. I am not sure how to measure impedence when everything is attached (but not powered) . Do yo uhave a reference how to do that?
Brian Puhl avatar
To stop windows updates, a simple way is to set your network connection to metered.   I've only ever had one update commence after doing this, windows really wanted to get that one done!!  That's over 2 years on 3 scopes.
I wouldn't rule out power as an issue, if you're running 12V from the same power source that runs the rest of the system, try isolating and providing it with its own power supply.  Try switching power plugs even, some aftermarket plugs, particularly from Amazon don't hold up well under load
Just my 2 cents.
+1 for the possible power issue
Make sure all your connection are tight
+2 on power and connections.
AstroRBA avatar
Any raccoons in the area ? They like to play around with things (and tug at power cords etc.) to see they’re edible …
*If you power you rig from the household electrical network you should be able to mesure the impedance with a voltmeter switched to read resistance. Just connect the two terminals of the voltmeter to the two powered prongs of the plug (i.e. do not connect to the earth one). If you power everything from a battery of sorts then the two terminals (red and black on most of them) should be connected to each end of the connector to the battery.
Keith Mombourquette avatar
In windows update settings you can set the hours when you don't want windows to run an update.  I set my active hours from 6pm to 8 am.  If windows is going to update it does so while the sun is shining.
Darryl Ackerman avatar
We use the NUC at work to run our video conferencing systems, they crash often, it's not Windows update, they're just not the best mini-PC's out there. I have 2 MeLE PC's I use for imaging. One running Windows 10 and the other Windows 11, never had either crash in the past 2-3 maybe 4 years.
sebaromano avatar
Brian Puhl:
Thank you. FOr clarification: the mini-PC runs with is own (original) power supply
sebaromano avatar
One more detail: the astro gear is in the backyard (on a fixed pier) and electrically connected to a power strip (high end quality and high power rating) which is then connected to the house (about 25 m) via an HEAVY DUTY extension cord. The cord is suited for high power tools (3500W) so it shouldn't be the cause of the problem. Should I measure  the impedence at the power strip end (with all gear connected) or at the extension cord end?
Well Written Concise
*At the end of the extension cord, where it connects to the house supply.
sebaromano avatar
*it's about 500 kohms so it should be fine, correct?
It depends on whether you have any switch open or not, it isn't terrible but isn't great either. Check that the power cord between house outlet and rig reads open (> 10 MOhm) when unconnected to anything. If it is then you are most likely fine on this regard.
sebaromano avatar
meaning I have to measure the impedence of the actual power cord from one end to the other and supposed to read > 10 MOhm ?
Not from one end to the other end, but between the two powered prongs/pins of the plug (ignore the earth one). It should read open or with very high impedence (> 10 MOhm). That will show you have no dissipation to the ground.
Mini PC crashing caused scope to hit mount
Looking for some help/advice please, on how to understand what caused my mini pc to crash & also how to stop the mount continuing to drive in the event of a pc hanging-up.. Following a recent imaging session I awoke to find my mount (an EQ6-R) ha...
Mini PC crashing caused scope to hit mount — directly addresses crash and mount control issues.
26 days ago
Windows remote app on iPad
I’ve recently switched to a Mele mini pc and NINA to run my astrophotography setup and connect remotely via the windows remote app on my laptop. I know it’s also possible to use the Windows remote app on an iPad which could be very helpful when I go ...
Windows remote app on iPad — uses mini PC and NINA for remote astrophotography setup.
Oct 14, 2025
New mini PC won't boot after remote imaging session
I got the new mini PC set up remotely and it’s blazingly fast, faster than I even expected. All went well on the first night of imaging with it. But this morning when I downloaded my data, I shut the computer off and it kept trying to reconnect. I as...
New mini PC won't boot after remote imaging session — mini PC issues during automated imaging sessions.
Sep 17, 2025
