Mount limits on GS server
1 reply32 views
clad shr avatar
Hi,my name Is Valerio, i wanted to automate more my setup, i installed nina and GS server, i tried doing the meridian flip, i setted 0 minutes After the meridian, started the sequence and First thing nina did was the meridian flip, even if the target was not on the meridian, my scope ended up crashing into the mount, does anybody know how to set the mount limits on GS server and what to set on the meridian flip in nina?Thank you
In GS I have the flip angle set to 0, In Nina minutes after is set to 10, max is set to 15, use telescope side of pier (on), recenter after flip (on), settle time 30 sec, pause before meridian 0.
These numbers have worked well for me. The way to think about is, the setting in GS is the time after meridian when it will accept a flip command. The first two numbers in NINA aer the window in which NINA will command a flip. The window has to be longer than your longest sub exposure time.
Hope that helps.
Need help: NINA meridian flip at wrong time
📷 Bildschirmfoto 2026-01-04 um 19.12.50.pngRecently, I've encountered the following problem in NINA: The time for the meridian flip is no longer correct, but all other times are displayed correctly. The system time in Windows is correct, and the lati...
NINA meridian flip timing issue matches author's problem exactly.
Jan 6, 2026
Possible NINA Mount Control Issue
I connect to my Tak EM200 mount using The Sky Pro 64 and control my imaging through NINA. This has worked well many times with the same sequencer templates. However, last night I had imaged up to the meridian, manually done a meridian flip and then s...
NINA mount control problems directly relevant to author's setup issue.
13 days ago
DST with StellaVita and Skywatcher mount.
Hello, I am having issues some issues with meridian flip not working and I believe it has to do with the mount settings. In my SV I have this in the mount information. We’re in DST time currently in Canada which is why there is a 1 hour difference be...
Meridian flip and mount settings configuration similar to author's needs.
Sep 12, 2025
CEM40EC Handset: "Unknown Position" - What does it mean?
I may be a little paranoid after suffering a tripod collision due to a known (but not to me) software compatibility issue between the ASIAIR and the CEM40 series of mounts. But I just noticed that as soon as I begin to slew after setting the mount ze...
Mount collision incident similar to author's scope crash problem.
Jan 28, 2026
Problem with NINA loosing pre set settings, and mount connection issues!
Hi, I have been a NINA user for quite some time, and very much like the program. I am not a software expert, and after a fairly long learning curve, I have been using this program pretty successfully. That was until last night. FYI, I am using the Be...
NINA mount connection issues relevant to author's automation setup problems.
Nov 18, 2025
