Connecting ASI2600MM Duo to Sigma (Nikon) Lens
15 replies384 views
Alicja Lombard avatar
I want to image wide angle areas of the sky, and for that I am using a Sigma lens with an astro camera, but I can’t obtain the focus. I have tried different backfocus distances, see below, but I’m unable to get anything close to focus. Does anyone have experience in connecting photography lenses with astro cameras? What am I missing?
My lens is a Sigma 24-70mm F2.8 DG OS HSM | A. I’ve been quite successful using this for wide-angle imaging with my Nikon DSLRs (D780 & D810A).
Per ZWO, the ASI2600MM Duo backfocus is 17.5mm.
The filter wheel is directly connected to an ASI2600MM Duo. The filter wheel is 20mm thick and provides an M54 interface.
A Nikon F-mount adapter connects the lens to M54 threads; it is 12.5mm thick.
Here’s what I tried.
Using the instructions provided in the documentation for the ASI2600MM Duo:
Filter Wheel = 20mm
Nikon F-mount adapter = 12.5mm
ASI2600MM Duo backfocus is 17.5mmm
Total back focus = 50mm ⇒ focus could not be obtained
Notes
This appeared to be the closest to focus, but was still badly out.
This is the minimum backfocus I can obtain with the required components.
As that failed, I contacted ZWO, who recommended this:
Filter Wheel = 20mm
Spacer between Filter Wheel and lens adapter = 5mm
Total back focus = 55mm  ⇒ focus could not be obtained
I also tried other spacer thicknesses, none of which worked. Focus appeared worse with larger spacers.
Spacer between Filter Wheel and lens adapter = 4mm
Total back focus = 54mm  ⇒ focus could not be obtained
Spacer between Filter Wheel and lens adapter = 9mm
Total back focus = 59mm  ⇒ focus could not be obtained
Spacer between Filter Wheel and lens adapter = 16.5mm
Total back focus = 66.5mm  ⇒ focus could not be obtained
Spacer between Filter Wheel and lens adapter = 21mm
Total back focus = 71mm  ⇒ focus could not be obtained
Spacer between Filter Wheel and lens adapter = 37.5mm
Total back focus = 87.5mm  ⇒ focus could not be obtained
Well Written Helpful Engaging
[deleted]
According to Nikon the backfocus for the Nikon F-mount is 46.5mm.
The Nikon F-mount adapter from ZWO is exactly the required 29mm -> https://www.zwoastro.com/product/zwo-new-nikon-t2-adapter-suitable-for-all-asi-cameras/
Edit: I guess you won't have any luck with a mono camera, as there is no F-mount adapter of only 9 mm thickness to allow for the filterwheel.
[deleted]
delete this
As others have mentioned the backfocus required is 46.5 mm (minus 1/3 the filter thickness). Depending on the FW make there might or might not exists a F-mount adapter. If you're desperate about making it work there are options to have one made to specs.
Thank you, you were very helpful. That is depressing. I guess I will have to go back to my Nikon D810A. I think ZWO needs to update their instructions for connecting a photo lens.
This chart might help...
https://en.wikipedia.org/wiki/Lens_mount
Thank you, the link is helpful.
Frankly, it is rather easy to make one.
Dan Kearl avatar
The T2 filter drawer goes directly onto the lens and the 2600 screws into the T2 drawer.
You might need to shim the camera to get flat field.
I have solved my problem.
The ZWO instructions appear to be too brief. I found more detailed instructions on theAgena Astro site. They had me remove the sensor tilt adapter, and that solved the problem by removing 5mm from the backfocus. I can now focus. Thank you all for your help.
Well Written Helpful Concise
Dave Erickson avatar
Here is an implementation of the suggestions above, that works under the stars and on the bench. ASI 2600 MC Duo Standard Spacers and Sigma Art 85mm for Nikon lens...
David DV avatar
The backfocus I needed to be able to focus was more then 17mm.    I attached a ZWO filter wheel + 16.5mm + 21mm connector pieces.  Then I'm at the edge of having sharp images although I push it near the other end.   My autofocusser doesn't work though as I attached a connector piece to much and it doesn't have enough space to go through a cycle.   Manual focus works fine this way.   (using Askar FRA500)
Dave Erickson:
What is the bracket your are using to support the lens?
I am using ZWO Nikon Lens Adapter for ZWO 2" Electronic Filter Wheel # EFW2-Nikon
https://agenaastro.com/zwo-nikon-lens-adapter-for-2-electronic-filter-wheel-efw2-nikon.html
But I am not sure how much of the dimensions actually account for a "spacer". I measure 12.5mm, but wish I could verify that number.
Its a ZWO holder ring "ZWO-RINGD90". one for the camera one for the lens. I added a bracket for the flip flat to the one on the camera.
For the Nikon Interface to the ASI2600mc-Duo I used the " ZWO NEW Nikon N54 adapter" There are 2 parts:
the first is a ring that adapte to the Nikon Camera. It measures 10.5mm thickness from the threaded land to the camera interface, not included are the threads.
the second is an M54 x0.75 threaded adapter ring 18.15mm thick. there is likely small production variations in these thicknesses..
The two components are shown below...
[deleted]
The normal Nikon F to T2 adapter is 29 mm, which results in the required 46.5mm when used with a camera that has 17.5 mm backspacing.
The filterwheel version consists of two parts and requires the 5mm thick tiltplate to be removed, reducing the backspacing of the camera to 12.5 mm.
Therefore, as the filterwheel itself is 20 mm thick, the adapter without the ring of the filterwheel version has to be… 46.5 mm - (12.5 mm + 20 mm) = 14 mm
Backfocus issue : Canon Lens With ZWO 2" EFW and ZWO Asi 183
Hello guys, I plan to use a Canon Lens with my cameras and A 2" EFW I have 2 cameras : 2600MM and 183 MM. I do not find issues for the 2600 : My lens + EOS lens adapter for 2″ Filter wheel + 2"EFW + ASI 2600 without tilt Ring –> it...
ASI2600MM lens adapter and focus issues with Canon lenses similar.
Sep 29, 2023
ZWO ASI2600MM Pro and QHY CFW3-M filter wheel connection adapters?
Hi everyone, I wanted to ask if anyone here is using this combination:ZWO ASI2600MM Pro camera (P25)QHY CFW3-M filter wheelIf you are using them together, which adapters did you use to connect them (M42, M54, spacers, etc.)? If you can share your exa...
ZWO camera adapter compatibility relevant to connecting lens with astro camera.
Dec 5, 2025
Back focus on Astro Camera wiith Canon EF Mount DSLR Lens
Hello, I want to buy a ZWO ASI533MC Pro which I will use with my Samyang 135mm lens for a while. I have read so many posts and articles about back focus in forums and blogs that I am not sure anymore that my brain can digest all the information. My u...
Addresses back focus issues with astro cameras and lenses; directly relevant problem.
Oct 17, 2023
