Power supply for astro imaging
11 replies310 views
[deleted]
Hi all, I'm looking for  suggestions regarding a good quality power supply for my astro imaging equipment.
I've realised that if I had a power supply failure due to high voltage output (which I have happened in the past with different equipment), there is a risk of damage to some expensive equipment.
I need a power supply with 13.5 volts at 10 amps.  It needs to be over voltage protected.
My mount, asiair plus and camera cost a total around £7000 and I don't want to risk damage from a cheap power supply failing.
Appreciate any suggestions of a high quality product.
I currently use a switch mode power supply, am not sure if a linear model would be safer or not.
I don't want to use batteries as have mains available where I image.
Rick Krejci avatar
I use and have trusted Pyramid power supplies for years.    I have the 12 amp 13.8 V linear one and it works great.
Tim Ray avatar
I use a 3D printer power supply from amazon. Clean - 3D mother boards vs Mounting MB's (same need for clean power), high current - easily handle 10amps. These PS's power heated build plates on 3D printers vs A much lighter load on a scope rig at high slews and high current settings.
Cheap - Amazon
I installed mine inside a plastic tool box. The tool box gives ample room for cables and other gadgets when not in use….
CS Tim
Médéric Hébert avatar
I run all my power through a Pegasus upbv3, worse that can happen is the upbv3 will shut off the power to the other devices. I had it happen before when trying to use a faulty power supply (15v instead of claimed 12v). Everything survived.
Arun H avatar
https://powerwerx.com/ss30dv-desktop-dc-power-supply-powerpole
if you are concerned about 13.8 vs 14.1V, you can use this one which allows you to select the voltage:
https://powerwerx.com/variable-power-supply-digital-meters-30amp
Bill McLaughlin avatar
Arun H:
+1 on these. I have a couple of the adjustable voltage ones. The only downside is that you have to be sure to not bump the voltage knob and change it to something higher or lower than desired. I made new knobs for that adjustment that can be locked in place. I machined mine but one could probably also 3D print one.
Well Written Concise
[deleted]
Médéric Hébert:
Just looking at this, it looks like may be what I'm looking for.  Expensive but compared to the cost of replacing everything if my current psu fails, not so bad
Médéric Hébert:
It also comes with other nice stuff, auto dew control on 3 port, switchable USB and power for when a device freeze. 2 variable outpout (3v-12v and 12v-24v). It is expensive, but I 100% get one again if I was starting over.
Brian Poole avatar
I run my dome controller with one of these:
https://www.amazon.com/dp/B00R5CHZAO
Voltage output is adjustable.  I can't remember what the range is on the voltage, but I'm pretty sure 13.5v wouldn't be an issue.
I also use a Pegasus Ultimate Powerbox v1 for my camera, focus motor controller, and temperature sensor.  I used to use it to power my computer, camera, and mount all at the same time though and that worked well.  If you want/need something that's scope mounted with all the extra features, I second the Pegasus Ultimate Powerbox.
Arun H:
Came here to suggest these both. Excellent units!
Wei-Hao Wang avatar
I know this is what you are asking, but I still want to say: over the past 15 years, I simply use a Toyota hybrid to power all my astro rigs in the field.  Works perfectly.
https://app.astrobin.com/u/whwang?i=77566#gallery
Stephan Linhart avatar
I am now using those :
MeanWell HLG-185H-12A 156W 12V 13A
for a while and I have to say they tick all the boxes. You can crank the Voltage up to13.8V and limit the current if wished.
It is IP67 and can safely lay in the grass, it will not get very warm and has a very „clean“ voltage.
The best is, it is cheap. But you have to add the connection of choice on both ends yourself. Which is OK in my case.
https://www.amazon.de/Amazon-Parent-MeanWell-Serie-HLG-185/dp/B01LWXUAC2?th=1
POWER SUPPLY: Diagrams Thread
Hello colleagues! The use of a power supply is often a headache for amateur astrophotographers (my case) and I haven't found a topic where this is discussed. I think it's a good idea to make a compilation of the schemes you use to power your ...
Directly addresses power supply selection for astro imaging equipment needs.
Sep 15, 2023
Best power supply for equipment?
I recently got a Sky-Watcher EQM-35 and I realized this thing eats a lot of electrons. Now I need a proper power supply and I was wondering what you guys would recommend and what you use for yourselves.
Directly addresses power supply selection for astronomy equipment needs.
Sep 6, 2023
DIY Power using the EGO tool battery
Here is a partial posting from an image posting I posted recently regarding a grab and go imaging rig. The hope is to reach a wider number of potentially interested people. I did search the site and even CN to see if there was anything like this and ...
Discusses power supply solutions for astronomy imaging equipment needs.
Jul 2, 2023
Exposure Failure on ASIAIR Plus
Im curious what equipment people are powering through their ASIAIR? I bought an ASIAIR Plus and set it up with my AM5/2600MC Pro and 270mm guide camera. I was getting Exposure failure messages on ASIAIR and I could here the fan knocking on and off (i...
Power supply issues directly caused author's equipment failures and frustration.
Aug 6, 2023
Recommendations for portable power banks
Hi guys, I'm looking to invest in a portable power bank for astro trips but I'm unsure which one to get. Ideally, I don't want to spend a fortune (I get the irony of that in his hobby), but equally, I want something that will last. The ma...
Directly addresses power supply needs for astro imaging equipment.
Mar 22, 2023
