Need Filter Recommendations for Lunar Photography
1 reply50 views
Eddie Bagwell avatar
I'm reaching out to my fellow Lunar photographers or anyone with good knowledge of Lunar Photography. My question is: What is a good filter for photographing the Moon? What part of the light spectrum is wanted and unwanted to achieve the best results?
I just purchased a C11 for this project and will be using the ZWO 462 and ZWO 432 mono cameras. In the past with my 9.25 SCT, I used the Optolong UV/IR Cut filter. Is this good enough?
Any thoughts or suggestions?
The UV/IR cut is always a good choice. Another interesting option is an IR pass. These filters usually open up at around 800nm and are very useful for calming the seeing so that even though you are loosing resolution you can often get a sharper result. Actually, an narrowband Ha filter will do that too so if you have one, it's worth a try as well.
Helpful Insightful Respectful
accessories for Zwo ASI IR-UV filter??
Hello. I have a Zwo ASI 294Mc Pro camera and a C 9.25. I bought a 2" IR/UV Cut filter from Zwo. But it doesn't fit inside any thread. Do I need any other accessories?
Filter recommendations and installation for ASI camera systems.
Aug 29, 2023
Recommendations for Windows tablet with good battery life for astronomy rig control.
Currently, I drive to remote sites and run one setup with a Mele computer controlling the rig. I use an iPad Mini via Windows App to control everything. I am assembling a second rig so I can run two setups simultaneously, but I really do not want to ...
Tablet control relevant to lunar imaging workflow with ZWO cameras.
Mar 2, 2026
Barlow for lunar photography?
Do I need a barlow? It seems too close to the moon already. I use an F/5 reflector. Light blue = 1600mm (1000mm 1.6x crop from FF) No barlow Green = 1.6x Yellow = 2x
Directly relevant to lunar photography techniques and equipment optimization.
Mar 20, 2023
Focuser and planetary camera recommendations for Skywatcher 150p Virtuoso GTI?
Hello and welcome id like to ask everyone who have this telescope. Im originally a Seastar user but ever since its being told that the seastar itself cannot do planetary imaging or observing i purshued this big boy. Its also an ALT AZ telescope but i...
Planetary camera recommendations applicable to lunar photography setup.
Aug 26, 2025
Seeking advice on next steps in my astrophotography journey
I’d really appreciate your views on the next steps on my Astrophotography journey. Having been doing this amazing and absorbing hobby now for just under two years, I know that my journey has progressed from bafflement with how to use the equipment an...
General astrophotography journey advice relevant to lunar imaging progression.
Feb 5, 2026
