Sensor tilt or focuser tilt? Please help :)
9 replies328 views
AstrophotoMarket.com avatar
I've perfectly adjusted the tilt on my astrophotography setup, which consists of an Esprit 120 telescope, a Riccardi 0.75x reducer, and an ASI 2600MM Pro camera with a 2" filter wheel.
However, I've noticed an issue when rotating the camera within the focuser -whether manually or using the Deep Sky Dad motorized rotator. Depending on the rotation angle, the tilt measurement changes noticeably. Although the tilt remains within acceptable limits for this setup, the issue becomes visible through distorted star shapes, particularly in the right corner.
Importantly, I verified that tilt measurements at a specific camera angle remain nearly consistent across different areas of the sky. Therefore, the variation in tilt seems directly linked to the rotation angle?
My setup: telescope, tilter, reducer, rotator, filter wheel, camera.
Could someone please help me understand the source of these tilt variations, especially considering the use of a mechanical rotator? Any insights or explanations would be greatly appreciated
Iosif Bodnariu avatar
Try only Camera and scope.
And add tilt, rotator, and filter well, one by one, and you will find.
This app to measure tilt where can be find.
Thankyou
It's the rotator. Less is more.
I wonder if putting the rotator behind the filter wheel might help, a bit less weight for it to deal with?
Lynn K avatar
I found that a Pegasus Falcon v1 increased my tilt on a FSQ106ED from 4-6% to 40% when rotated 180 degrees. I have a Pehasus Falcon v2 , but have not tested it.  I would suggest, as proposed in preveious post, to first test camera tilt in the most orthogonal set up you have. Do not worry about coma, because all corners shpould have equal coma in the stars in a flat chip.  Trying to matain correct back focus from a flattener or reducer in chip corrers while correcting chip tilt is near impossible.
Lynn K.
Craig Towell avatar
Get one of these and you will know for sure where the tilt is coming from, and if it’s the imaging train it’s very easy to sort in a few mins indoors, during the day in the warm, if it’s the focuser, then at least you know no can sort..👍🏻
https://youtu.be/iyH7vsAqcDA?si=-vmTMi08_7YzeRQK
Really nice piece of kit that is
Dan Burns avatar
Get one of these and you will know for sure where the tilt is coming from, and if it’s the imaging train it’s very easy to sort in a few mins indoors, during the day in the warm, if it’s the focuser, then at least you know, and then can sort..👍🏻
The April Sky and Telescope has an article on page 62 by Chris Schur describing in detail how to make a laser camera tilt tester.
Canon EF 300mm f/4 L astrophotography comparison: non-IS vs IS version
Hello all, I am excited to share this test report I wanted to make ever since I acquired both lenses, in an effort to help the community. I will also attach it to the thread for easy download. Enjoy your read and I hope this comparison helps you make...
Irrelevant - discusses Canon lens comparison, not telescope setup issues.
Feb 3, 2026
Tilt!
Hi folks: I seem to have a bit of a nasty tilt issue that has crept up on me. I've never had perfect stars in all corners but the coma was pretty minimal so I didn't let it bother me. In the last 9 months it's become much worse, though, t...
Focuses on sensor tilt adjustment and diagnosis methods.
Aug 19, 2023
EFW of choice?
I need to add a 7x50mm EFW to my collection and although I've been happily using the ZWO ones without issue, I'm thinking of another brand. I've only see one review on the Indigo, but it wasn't favorable. QHY has theirs, but is there ...
Mentions ASI260 camera; relevant to author's ASI2600/6200 camera compatibility concerns.
May 15, 2023
A spreadsheet to convert Hocus Focus result in pratical move/turns of a manual tilt adapter plate
Hi, I recently got a wanderer astro ETA. It works great but I wanted to better understand the way it works and I asked OpenAI to prepare a spreadsheet to check what the ETA was doing and also to use old Hocus Focus results as the ETA works only for t...
Relevant - addresses tilt adapter plate adjustment and measurement tools.
Jan 7, 2026
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Relevant - discusses ASI 2600MC camera artifacts, same camera model as author.
Nov 27, 2025
