Nina compability and filter offsets
1 reply94 views
Tobiasz avatar
Hello,
I ordered a Scops with the goal to always have perfectly focused stars with my OAG when the filter changes. This is especially important for times of bad seeing, where the slightly defocused stars have low SNR to be guided on. I am guiding with Metaguide so guide star FWHM is really important.
My question is does someone of you have the scops integrated in Nina with filter offsets? So when the filter changes to a new offset, the scops also adapts a new focus point to achieve perfect focus again?
As far as I can tell NINA is only able to connect to one focuser per instance, which means you can use your EAF or the scops but not both.
There may be workarounds with two instances and scripts but I could not find a guide or explanation. I am thinking about writing mini scripts that are executed on filter change which tell Unity's API to set the Scops to a specific focus point. However, I don't know if this will work.
That's why ask in this thread if someone managed to get it working and might tell us how he or she did it.
Appreciate the feedback
Tobi
Respectful Engaging
Tobiasz avatar
Update on my part. Native support of filter offsets from Nina or ASCOM side is non-existing. Yes, you can select the Scops as a focuser and it acts like one but that's it. Thankfully NINA allows the use of external scripts in sequences which enables you to use specific focus points of the Scops and call them via the Unity API.
This way you can do the regular filter change in the sequence and your scops adapts itself in the background.
Next step: focusing the OAG to every filter I have (LRGBSHOIR), which will be much easier than with the downright bad focuser of my Indigo OAG…….
Could not find guide star with the Celestron OAG and the ZWO ASI 220mm mini camera
Tonight I was using the Celestron Edge 8 with the Celestron OAG. I simply could not find a single guide star while looping, I didn't even get as far as calibrating because no guide stars were showing up in ASIAIR Plus. I tried swapping the ASI 22...
Filter focus offsets relevant to OAG guiding setup troubleshooting.
Aug 24, 2023
External focuser on an SCT; What about temperature change induced focal shift and back-focus?
It seems like every serious astro-photographer is putting external focusers on the back of the EdgeHD telescopes and locking the mirrors. I picked up a nice little EdgeHD 8" and a Primaluce Lab Esatto 2" LP focuser and gave it a try myself....
External focuser handles temperature-induced focal shift relevant to filter offset focus.
13 days ago
Would i benefit from moving over to an oag?
Hey guys, i would love to know if the quality of my images would benefit by using an oag. rn i am using an 30mm mini guidescope with an 2.9 micrometers pixel size guide camera. The scope it sits on is an esprit 120 used at two different configuration...
OAG filter offset discussion directly addresses author's OAG consideration.
Nov 3, 2023
Focuser trouble when NINA starts
Hello, I’m new to NINA (was using ASIAIR before), I was able to connect and set everything and to perform two nights of imaging. Here is my issue, the last two times I turned all my equipment on, my focus was lost (I mean stars wereway out of focus, ...
NINA focuser connection issues directly relevant to NINA filter offset integration.
Sep 3, 2025
Trying to align sensor edge with OAG-L prism
Hello. I have purchased a ZWO EFW and OAG-L to use with my ASI183mm and 174. I am trying to set up the 183 with the OAG-L prism. The 183 simply screws onto the EFW, so the threads dictate where the sensor is angled with relation to the prism, so one ...
Discusses OAG filter offset alignment concerns relevant to camera positioning.
Jun 29, 2023
