Autofocus with OSC and Different Filters
2 replies•145 views
I never used an AEF before so I'm out of my confront zone, so to speak. So here is my problem: I'd need to use NINA autofocus capabilities (either the embedded one or Hocus Focus plug-in) but with different filters with different optical thicknesses and presumably different focus curves. Problem is that I use a filter drawer and manually switch from one to another as subject and opportunity command. Can those curves be saved and used in the standard sequencer or I need the advanced one, if at all feasible? What are my options, if any?
Thanks in advance for your help in this matter,
Andrea
jmdl101 avatar
I use an electronic filter wheel and just autofocus when I change filters, takes about 2 minutes. Nina has a filter offset calculator plug in also that you can use to set offsets for each filter if you want to try that out. In theory you could change the filter, chnage the filter in Nina, and then it would automatically move the focuser the correct amount for that filter.
Noah Tingey avatar
What @jmdl101 says is true. Set up your filters in NINA as if you had a filter wheel (treating "no filter" as one of the filters, assuming you do that sometimes), but then connect NINA to the "manual filter wheel" dropdown option in the equipment page. This will work as if you have a filter wheel, but it will pause the sequence and prompt you every time it wishes to change a filter.
If you're doing more than one filter per night, it might be worth setting up filter offsets. Takes about 30-60 minutes with a full set of SHOLRGB, but the upside is that you don't have to re-focus with each new filter. Just focus once on one filter (or with no filter) and NINA remembers how much it needs to adjust your focus based on the offset.
Focuser trouble when NINA starts
Hello, I’m new to NINA (was using ASIAIR before), I was able to connect and set everything and to perform two nights of imaging. Here is my issue, the last two times I turned all my equipment on, my focus was lost (I mean stars wereway out of focus, ...
NINA focuser connection issues relevant to autofocus setup problems.
Sep 3, 2025
How long does it take to auto-focus?
Never did this and I wouldn't but I may have to. So this is the question: Suppose to have to refocus during an acquisition run using NINA, how long would it take with an autofocuser (any EAF really) to achieve focus starting close to focus. For e...
Autofocus timing during imaging runs directly addresses refocus duration concerns.
21 days ago
Autofocus questions
In the past, I've generally run an autofocus every 30 minutes (I don't have a temperature gauge on my rig). But I've recently switched to NINA and have used the autofocus on HFR change (default of 5% over 10 images). But no autofocus run ...
Autofocus scheduling strategies applicable to multi-filter imaging workflows.
Aug 13, 2025
