Help me understand the hype behind dithering
13 replies509 views
Please let me know if you Dither your images or not
Multiple choice poll 81 votes
90% (73 votes)
7% (6 votes)
2% (2 votes)
AstroShed avatar
I see many many people swear by dithering, and I know it’s needed for drizzling, so that aside, what other reason do you dither.
i have never dithered, not even tried, and yet my images turn out fine, now I always to use a good set of temp matched darks, with my QHY268c and 268m, and these seem to remove all  the noise, walking noise and hot pixels, which are very evident before the calibration frames.
So would dithering just negate the need for the darks, ? Or is there another scientific reason for them that I am missing
Thanks
It is like asking yourself: do I need to calibrate my images. If the answer is yes then I don't see any reason NOT to include darks in it. Once done good for ever (well, for a pretty long time anyway). The only exception is when the camara is uncooled in which case either dithering or random shifting is proffered (and a large set of frames). Even then I never dithered even with DSLRs. And managed ok with my workflow (but that might not work for all set-ups). YMMV.
Kyle Goodwin avatar
Yes, you must dither to prevent walking noise and other noise issues which do not calibrate out otherwise. If you want a quality result, especially on faint targets where you’ll stretch aggressively, dithering is not optional. I’m sure someone is going to come up with a counter example and show some image where they didn’t dither and got IOTD or something, but unless that someone is you and you know exactly why dithering doesn’t apply to you, you should definitely do it.
Well Written Helpful Insightful Concise Engaging Supportive
AstroShed avatar
Kyle Goodwin:
Well I have stated why I don’t do it, a good set of temp matched darks, at least 50 of them combined into a master get rid of all my walking noise, so why would I need to dither too, that is the question, I understand that some people no longer use darks, so they would need to dither to remove walking noise, but in my case I do use them.
What am I missing here, obviously something..🤔
AstroShed:
Or not...
AstroShed avatar
AstroShed:
Or not...
We seem to be in a real minority with this opinion…🤔
Before I incorporated guiding in my setup I would have to periodically re-center the image because of drift.  I shot a lot of frames (still do) and always re-centered to a slightly random point. I wasn't trying to dither because I didn't know about it at that point. It was just faster to not be too precise. When I started guiding, my images were suddenly swamped with walking noise, that was with well calibrated data. Dithering fix that issue so for me, it's something I have to do. That said, it does reduce total integration so I try to minimize it as much as possible. With 15 sec subs I dither on every 20th frame, that seems to be the right balance for my setup. I would love to not do it but that's just not an option for me.
I should mention that I shoot in a  Bortle-8 zone.
Kyle Goodwin avatar
Don’t use darks, don’t dither, whatever floats your boat. There’s tons written on why to do these things, but the deleterious effects of not doing them have become less impactful over time as technology has improved, so there’s always a portion of imagers who will find it to their personal preference to take the opportunity of that improved technology to shortcut parts of the process. My feeling is that I spend way too much money, time, and effort on this hobby to not try to do it to the best of my ability, without shortcutting the process. Even with no walking noise there’s lots written about the sampling benefits of dithering to avoid having the same pixel read the same bit of sky on every shot.
Astrogerdt avatar
Well, as stated in the beginning, the real benefit is drizzle in many cases.
However, even with a good dark frame calibration, the dark frames will always add some noise on their own into the light frames. If you have significantly more lights than darks, which happens often for me, you might end up with a lower amplitude fixed pattern noise in your frames again. Again, dithering helps here.
Also, even with good flats, there will always be some non uniform responsiveness in the pixels. Dithering helps again.
So in conclusion, besides drizzling, most things that dithering died are better done by other techniques. Dithering is just a simple yet extremely effective option to get rid of all the residuals that are inevitable and make sure you don't miss anything.
For me, it is a very cheap and easy fix for otherwise complex problems.
CS Gerrit
Astrogerdt avatar
And just to add to my last post, as this is pretty often overlooked: for drizzle to work AT ALL, it requires well dithered data. Otherwise, the application of drizzle makes no sense and is completely ineffective from. The very beginning on.
CS Gerrit
John Hayes avatar
AstroShed:
What you are missing may be a clear understanding of the statistics of image calibration.  First, you don't need a stack of 50 subs to create a master dark.  16 subs are generally fine for just about any size stack.  (I worked out the math to show this a number of years ago but I won't reproduce it here.)   Second, dithering is a method of mitigating the effects of fixed pattern noise (FPN), which is due to PRNU (photo response non-uniform) across the sensor.  FPN is proportional to signal strength.  PRNU is pretty small in most modern CMOS sensors but it is not zero.  In order for dithering to work well, you need to set the dither distance to be more than the autocorrelation distance of the FPN, which isn't always easy to determine.  I typically use 10 pixels but that's probably just barely enough.  15-30 pixels with most CMOS sensors is probably better.  If you want to learn more about this stuff you might read Janesick's book, "Photon Transfer".  (https://www.amazon.com/Photon-Transfer-Press-Monograph-PM170/dp/0819467227/ref=sr_1_2?crid=BYMB3OSWR046&dib=eyJ2IjoiMSJ9.bsMWECwhdB6KFZs5b3-nbYW83L0m5-sTbAPVExU5uuABNLPs5XBfDxf7z0bjG6z9YW1qYtFmwwiaP4qYzCpb4_LEp63bYCrCGB4IIxi0gIfQQMG_AlmV-RYTdnZQnRYZmRwHaeeNkFy0ZXeY2E-Yg0042pXcHCzERBkXos5843rmGLz6lwFPJsrX2BYq_jiMMP3ajUcqsBwaXFeQJiWj7xkv_izX3LLjaR_MVbS3cMMT-fTKukzyFj6UU1dxUyUp.CfaMa7kK8Oj4Bjgvmvq1McGFga6Gv5H8ugd7JWVNzh8&dib_tag=se&keywords=photon+transfer&qid=1741533777&sprefix=photo+transfer%2Caps%2C188&sr=8-2)
Even better,  Berry and Burnell's "Handbook of Astronomical Processing" provides an outstanding review of image calibration.  Unfortunately, it is out of print.  I found a copy here but it is super pricy:   US_Shopp_Textbookproduct_id=COM9780943396828USEDkeyword=&gad_source=1&gbraid=0AAAAAD3Y6gvnc32UkfTSPB8LqD-EcBrTY&gclid=Cj0KCQiAlbW-BhCMARIsADnwasoAoZFb3aH6AcIiNPzLP7ssQ0ocek42liE5Ps1W1XJlc7YoQN1o-74aAmRBEALw_wcB">https://www.abebooks.com/servlet/BookDetailsPL?bi=31953293771&dest=usa&ref_=ps_ggl_11147913055&cm_mmc=gglUS_Shopp_Textbookproduct_id=COM9780943396828USEDkeyword=&gad_source=1&gbraid=0AAAAAD3Y6gvnc32UkfTSPB8LqD-EcBrTY&gclid=Cj0KCQiAlbW-BhCMARIsADnwasoAoZFb3aH6AcIiNPzLP7ssQ0ocek42liE5Ps1W1XJlc7YoQN1o-74aAmRBEALw_wcB
You can ignore all this stuff and produce pretty good images, but if you want the very best results, proper image calibration is critical.
Helpful Insightful
AstroShed avatar
All very good points and interesting thread, glad I asked the question, thanks all 👍🏻
Wei-Hao Wang avatar
Hi John,
Thanks for pointing this out.  >10 pixels is also my observations, although I don't think I really understand it.  Do you know what does cause this correlation length of >10 pixels?  In CMOS, every pixel should be independent.  Even on interpolated images from Bayer arrays, the correlation shouldn't spread over 5 pixels.  What can cause correlation over >10 pixels?
John Hayes avatar
Wei-Hao Wang:
Hi John,
HI Wei=Hao,
You are completely right that CMOS amplifiers are independent from each other but there are bulk material effects that can cause the responsivity of each pixel to vary a little.  Remember that the entire sensor is made on a single piece of silicon.  In the early days of CMOS, FPN was huge!  Modern sensors have very little FPN so dithering more than 10 pixels may not be necessary but it certainly won't hurt anything either--and it's only a very tiny percentage of the total sensor dimension.  Most of the FPN that I observe in my IMX455 sensors is in the form of warm and/or dark pixels, which won't require more than a couple of pixels worth of dithering to mitigate.
