2nd attempt of photographing the orion nebula
9 replies330 views
Rakeen avatar
Stacked file:
https://drive.google.com/drive/folders/16dPNEaOd4yJ48cpHrk2Bm0Cr7WGOzLbD?usp=sharing
I've had a try once again and this is what I got. Maybe better than last time but I don't know what to do with the noise. Link above includes the stacked file.
https://i.imgur.com/FqibOF6.jpeg
dad's old Nikon D5300, NIKKOR 18-140mm lens, Dusty old tripod & Bortle 6-7
How should I make it better?
Rob avatar
I'm not sure what you use to process your data.  You can accomplish decent results with Siril and GraXpert if you don't have access to Photoshop or PixInsight.  GraXpert has a denoise feature now.   Here's a quick result with your data as an example:
Helpful Concise Supportive
Rakeen avatar
Rob:
I just used siril no graxpert.
TiffsAndAstro avatar
Rob:
only had a quick look. did you take/process flats?  there is a circle around m42 that might be fixed with flats.
having said that, i wish my second attempt at m42 was this good
Rakeen avatar
TiffsAndAstro:
Rob:
yes i did do flats
thank u so much for thecompliment akhi
GiffS avatar
Focus seems slightly off. I strongly suggest you get a hold SETI Astro’s stand alone editing suite. It’s free and has some very powerful tools that will help your post processing.
Any pixinsight dodgers (like me) need graxpert beta, seti astro suite &  cosmic clarity and gimp. And siril, obviously.
TiffsAndAstro:
+1
GiffS avatar
Just FYI I believe Frank ( SETI Astro) launched a stacking capability today. Haven’t checked it out yet.
Rob avatar
Just in case you're lost on SETI Astro's site looking for it, here is the suite link:  https://www.setiastro.com/seti-astros-editng-suite
Need help with Flat calibration
Hi guys, I’m in a big problem for two months and couldn’t find a solution. In my remote setup of Skywatcher-250 Quattro, I’m consisting getting dust donuts in low height areas, maybe light polluted sky area. I know that easiest way is clean the filte...
Addresses dust issues in astrophotography stacking, relevant to noise/quality problems.
Feb 17, 2026
