Help with gradient in the final mosaic
3 replies102 views
Emilio Frangella avatar
I am processing a two panel mosaic of Andromeda. I have an issue with PMM were the target image presents a dark gradient towards the center (see screnshot)
I have tried adjusting the various gradient parameters (especially the ones for the target image) without much success. I have had this with the L filter, but i solved it by carefully aligning the black points before stitching it together - now i have it also with the Red filter but aligning the blackpoints doesnt help. Does anyone have tips on how to solve this?
Have you tried the standard method?
Médéric Hébert avatar
Any chance you got some lights in your darks? It gives results like that.
Wei-Hao Wang avatar
If this is a two-panel mosaic, the overlap seems very small.  This can always be a source of various kinds of problems.
In PMM, personally I found the most impactful parameters to be scale and smoothness.  If you can show the various graphs that PMM generates, people here can help better on diagnosing the problems.
Well Written Insightful Respectful Concise Supportive
Tips on processing LRGB data, NGC1333, Dark nebula
Have 2 nights of data on ngc1333, looking for tips on how to process, 1. rgb data - have a lot of gradients due to light pollution. This is causing me to have a colour cast issue after using DBE to eliminate gradients. 2. Processing luminance data fo...
Gradient removal techniques directly applicable to author's RGB light pollution issue.
Oct 20, 2023
Mosaic creation - any good tools?
I have been trying to create wide-field (100 sq square degree+) mosaics for some time now. Although I have had some success, I am a little surprised by the lack of any good, easy tools in the various software suites. Particularly when compared to sof...
Mosaic creation tools discussion relevant to two-panel mosaic processing workflow.
Feb 1, 2026
Astro pixel Processor - How to combine a OSC broadband image and Extracted Ha and OIII from a dualband filter?
Hello All, I have a 2600MC-pro and have been using APP for a couple of years. I normally am only using 1 filter so no issues stacking. APP has been great. Now I would now like to take broadband subs and add the Extracted Ha and OIII from my antlia AL...
Multi-filter image combination in post-processing similar to author's Red filter issue.
Sep 5, 2025
