Need help or tutorial for M57 (or similar PNs like cat's eye) processing
21 replies632 views
YingtianZZZ avatar
Hi everyone,
I'm recently retry processing my last year data on planetary nebulas of M57, M27 and cat's eye nebula, but still cannot get the key idea of merging center region and surrounding fainter areas. This is an example of high-stretch and low-stretch for surrounding and center regions of M57, but the problem is any way merging them will produce dark circle around the right center. I also attached the H/O channel , each one actually show much details but after channel combination and STF they got so faint. I really hope to learn some more tips processing them like how to generate the masks and how to deal with edges, but there are too few  tutorials to follow. So, my experienced friends, could you give me some advices for processing these small but challenging objects?
Yingtian
YingtianZZZ avatar
I'll update a google drive link for H/O channel in case anyone is interested have a try. Thanks!
YingtianZZZ avatar
Your image scale is way too large for your seeing and the link only has the Ha channel.
Scott Badger avatar
If you’re using Pixinsight, GHS would probably let you stretch the inner and outer regions as you want without separating them, and/or using a mask. Otherwise, I would stretch the whole image as far as the inner area allows, then apply a binary mask (in Pixinsight, made using the Game script) that’s been heavily convolved (blurred edge) to protect the inner area while you stretch the outer area further.
Scott
Try light asinh stretch followed by a generalized hyperbolic stretch.  I don't know what these are called in PI but I'm sure there are equivalents.
Michael Maas avatar
This is how I would approach processing these images:
1) Star align the Ha and OIII images with the RGB
2) Run BlurXTerminator in the correct only mode on all three images
3) On the RGB plate solve and run either PhotometricColorCalibration or SpectralphotometricCollorCalibration
4) Run BlurXTerminator on all three images, then run StarXTerminator on the Ha and OIII to remove the stars, on the RGB image generate both a stars and starless image.
5) Run NoiseXterminator on the Ha, OIII and RGB Starless images
6) Stretch the Ha, OIII and RGB Starless images so that the max white level is like 0.85 and the background levels are about the same.
7) Stretch the Stars image with ArcsinhStretch
8) Using Pixelmath using and unchecking "use single RGB/k expression"
Use the following formula in the Red channel:  iif(RGB>ha,RGB,Ha) where RGB and Ha are the names you made the images
Use the following formula in the Blue and Green channels:  iif(RGB>OIII,RGB,OIII) where RGB and OIII are the names you made the images
On the destination click on "generate new image"
When you execute this by clicking on the Square button it will put the greater value from either the RGB and Ha in the red and either the RGB and OIII in the Blue and green channels.  Where the RGB has low signal the Ha has a higher signal it should replace those values and likewise in the blue and green.  You might have to scale the images by using X*Ha for example to tune down too much Ha or increase it.
after your done you might have to adjust the colors and or backgrounds to get back to a better and more accurate image.
An alternative method would be to generate a synthetic colorized Ha and OIII images using NBColourMapper and then use HDRComposition.
There are several ways in PixInsight to increase the dynamic range of the final image and how they work  will be dependant upon the quality of your data, so one way usually works better than the other, you just need to experiment.
If you post the RGB and Ha you might get more replies and better recommendations.
Good Luck
Dominik Weinbrenner avatar
Delinearized with MaskedStretch and HDRMT applied in the non-linear stage (with a mask only targetting the bright core).
YingtianZZZ avatar
Dominik Weinbrenner:
This is a wonderful processed image! I also expected to process out something like this but never succeed, I'll try your process!
Best
Yingtian
YingtianZZZ avatar
Michael Maas:
Good Luck
Thank you Michael! I didn't collect RGB image for this target but only RGB channels, but I process stars in a similar way. My problem occured at step 6, when I use HistogramTransform, usually a not overexposed center also means dark surrounding area, or do you mean using both HT and CurveTransform?
YingtianZZZ avatar
Thank you for your advice! I may try downsample due to my poor seeings.
The O channel is here: https://drive.google.com/file/d/175dGvbhTPduJj36ttETHMh-ePst1udRZ/view?usp=sharing
H channel: https://drive.google.com/file/d/1WiqaeTCqGgWXWkj67zy2aQW9SUQM7nxv/view?usp=sharing
Michael Maas avatar
Thanks for the data, still working on it but my first attempt was no where as good as Dominik Weinbrenner attempt above.  He got a lot of detail and was able to control the noise, my approach had difficulty with the noise floor and holding on to the faint detail.
John Stone avatar
Can you describe the parameters you used in MaskStretch and in HDMRT?   Can you post the mask you used?
John Stone:
MaskedStretch: 1000 iterations (maximum) and a target background level of 0.02 if I remember correctly (it's based on the median background level in the image, you can use the readout cursor to get an idea of the value).
The mask is a simple RangeSelection mask with a cutoff below a certain brightness. Use the "screen" function to see where that cutoff is and dial it in using the slider so you attack only the inner part of the ring.
HDRMT: Layers 4 or 5 (I don't remember sorry), 1 iteration, B3 spline scaling, "lightness mask" checked.
John Stone avatar
Ha image.
Start with (STF):
Masked stretch
STF off:
STF on:
Mask:
HDRMT:
STF ON:
STF OFF:
I hope you can take another look and reproduce your amazing result and then teach us how you did it.
Thanks.
My bad, a mix-up of terminology caused by replying from my mobile with no PI available.
In masked stretch, your target background level should be in the range of 0.125-0.2. This defines the amount of stretching that is done to the image.
If you put 0.002 in there, which basically is signal in linear state, no stretching is done, which is why you still needed an STF to even see your background.
What I meant was to set the upper limit of your background reference to the read out value.
Your RangeMask looks okay, you might want to increase the cutoff a bit more, otherwise HDRMT will give you overcorrected (black) areas in the transition zone between bright core and dim shell.
Helpful Insightful Respectful
Michael Maas avatar
This has been a very informative post, I have learn a lot from all the comments.  Using the maskedStretch and then generating two clone images, one for the bright parts of the nebula and another for the dim parts .  I did this for both the Ha and OIII channels.  I also had a OIII and Ha image of the stars that I used to generate the star image.  After I had the bright and dim images I just used pixel math to add them together with rescale option turned on.   I generated the attached cropped HOO image.  It took a bit to keep from generating the dark edge you discussed.
Hope this helps and it was very interesting hearing all the possible solutions
Michael
Helpful Respectful Supportive
YingtianZZZ avatar
My mask still not fitting center region perfectly (maybe I should lower it a bit to cover more center), but I think I've done most part of protecting center to global lightness.
Thanks to Everyone! Besides, may I include your contents if I make a tutorial? @Dominik Weinbrenner
Yingtian
Sure, all public knowledge.
Roger Renberg avatar
Hei,
I have the same issue with my images on these objects. My knowledge of PixInsight is very basic, so bear with me.
I like to use the WBPP tool when I process the images.
Are there some settings I need to be aware of, or can I use the standard recommended setting PixInsight recommends?
Thank you
Roger
Respectful
WBPP does not process an image, it just allows you to properly (or not) calibrate and stack a set of images in one final master image. That's all. Insofar as WBPP is concerned the standard procedure should suffice for at least decent outcome.
YingtianZZZ avatar
Roger Renberg:
Hei,
Thank you
Roger
Don't worry about WBPP now, as long as you have all the Dark/Flat/Bias/Light frames. Only thing to take care is is it's very bright, you can shoot more frames with shorter time to avoid blowing out the bright part. Otherwise it's just normal WBPP. This post is more about going after that, how to keep bright/dark part balance.
Great start to the new group
I've been wanting to organize this for a while, so thanks for jumping right in. It's fun to see so many great images coming from our club. Clearly everyone so far has some experience and a nice rig, and Ara is in another class. Hope to see so...
Processing techniques relevant to improving astrophotography skills mentioned in post.
Oct 21, 2023
[RCC] Galaxy post processing M101
Request you to provide your critique - It is my first attempt to post-process galaxy data. I obtained the data from TAIC workshop. The LRGB subs were already stacked and registered, even cropped to good extent. I proceeded with these steps, providing...
Addresses post-processing challenges with combining different image regions effectively.
Aug 19, 2025
