I'm working on the NGC 2070 image from JWST. No problem with the download. However, I can't seem to get the different filter images to align in Pixinsight. This is evident when I look at the combined image (090B, 200G, and 470R). When I look at a bright star on the left side of my image (see below), it is obvious that the blue channel is not aligned with the other two. The problem is not consistent over the entire image. The center, for example, is fine. The upper right is misaligned, but the lower right seems OK. Things I've tried.
1. The images are different in size. Resampled to approximately the same size. No improvement
2. Tried using a different filter to align to (e.g., rather than 090, used 200). No improvement
3. Tried thin spline. No improvement
Suggestions?
Thanks in advance, George
Suggestions?
