Please give me accessories and equipment suggestions for the Flurostar 91 APO William optics
11 replies371 views
Hello, I would like to have some suggestions for equipment because i'm having trouble finding accessories that are good. Also please give me some places to go look at the night sky with
Single choice poll 4 votes
75% (3 votes)
25% (1 vote)
[deleted]
Zmanbremerton avatar
If you are looking for camera accesories, I recommend the ASI6200MC camera.  I use it on my FLT91.    For dark skies, go across the Hood Canal bridge and head down Hwy 101 to Quilcene.  turn off on Penny Creek rd and get up on the hillside.  You have a great open area to the south for viewing.
John Rush avatar
I would reach out and see if you have a local astronomical society or club in your area. They probably have some good ideas for places to observe or may have their own observatory.
As for accessories it depends on what you would like to do. If you want to do imaging you need a camera. I like the ASI2600MC but others will work as well. I also use the ASI Air as the control computer for my mount and cameras.
Chaser_of_Photons avatar
Main: FLT 91 / ASI2600MC Pro
Guiding: FMA 180 Pro / ASI290MM
  Mount: Ioptron CEM40
 ASI Air Pro (now Plus)
Solid, reliable setup.  Guiding numbers consistently below 0.35
Martin Curran avatar
I use mine at full FL, so I have the 68III flattener. Other than that, I just use a ZWO focuser.
Ed Dixon avatar
The key things you will want to find include:
Mount
Flattener
AP camera
Guide scope and camera
Computer to control scope stuff
iOptron makes great mounts, and their more recent entries do not usually require a counter weight.  Today I use the HEM27 with my ZWO FF107 (similar to the WO 91) as well as with other bigger scopes.  The HEM27 also has a built-in polar scope, which makes doing a PA much easier.
Get the WO flattener for the 91.
I use a ZWO ASI2600MC camera, which is hard to beat.
WO has some great guide scopes.  I use the WO 50mm model with a ZWO ASI678MM camera.  I also have the WO 32mm guide scope for smaller shorter focal length scope setups.
I use a miniPC at the scope for all control and capture duties.  I have a powered USB hub velcrowed to the tripod, which makes connections much easier.  I used to have a ZWO ASIAIR, but found the miniPC worked better for me (wider range of software can be used).
Being older now, I want to be inside doing all control activities (warm in winter and cooler in summer). I use a WiFi adapter at the scope and a Jackery power model for all power needs.  This means that there are no wires outside the footprint of the tripod.
DavesView avatar
I've got the FLT91 with the 68III flattener. I had an ASI6200MM-P on it, but changed it to the 2600MC-P. Re: slight vignetting in the corners. Moving the 6200 to the UltraCat 108 with a larger image circle as soon as it comes out. I tried using the 6200 with an ASIair+ and it would time out on autofocus and alignment. The 120 meg files are more than the ASIair can handle. Also while the image was processing and displaying to screen, the AA+ would disconnect and reconnect. I also have the 6AIII reducer, but no longer use it for several reasons. One being that once the image train is working, tilt adjusted and backfocus set, I don't dink with it. I currently have an ASI2600MC-P on it and love it. You can't go wrong with the ZWO AM5n mount. I have the AM5 and the ease of use is unbeatable, although PA can be a little unfriendly when cinching it down. It tends to move, so technique is key to  success. I since have moved the FLT91 to a WarpAstron WD-20 mount and run NINA on a Ryzen 7, scope mounted mini PC. It is OnStep based, so unless you have a lot of patience getting use to the intricacies of that mount, I wouldn't recommend it. Having said that, I hated it for 2 months and now I love it. Kudos on the ZWO focuser. I found that I was mostly out of focus when relying on my poor vision and a Bahtinov mask. Now, every scope I have gets the auto focus. A rotator is really nice. I have the Pegasus on my FLT91, but plan on ordering a couple of the new ZWO CAAs for other scopes running ASIair+. Pegasus has some nice power and USB hub solutions and I use the UPBv3 for the FLT91. Filter wheels keep you from having to handle your expensive filters. I tried the filter drawer path and dropped a filter in the dirt one night. Ruined it and have gone filter wheel on all my scopes. Finally, don't be shy… get that credit card out and buy, buy, buy. smile
[deleted]
Thanks so much also could you tell me where to buy this stuff its to much workd to copy paste evrything thanks for the suggestion
DavesView avatar
Depends on which country you reside in. I live in the US and have two main sources: Woodland Hills (telescopes.net), Agena Astro (agenaastro.com). Others might choose differently.
[deleted]
Im USA NY
John Rush avatar
I like Agena or Highpoint prices tend to be comparable between them.
DavesView avatar
Im USA NY
High Point Scientific is located near you, so short ship times. highpointscientific.com
Newt to complement 80mm APO?
I currently image with a TS Optics 80mm APO (544mm, f/6.8) on a SkyWatcher Wave 150i, with a Touptek 533 and filter wheel. The image quality is great, but under Bortle 7–8 skies here in Ireland, the limited number of clear nights means f/6.8 forces m...
Author seeks equipment suggestions; post discusses APO telescope accessories and setup.
Oct 23, 2025
William Optics FLT Dew Shield
Hello, I want to ask if there is a way to remove the dew shield of the William Optics FLT91 scope? I know it can be retracted but l'm trying to remove it to be able to put it in a travel bag. Can you please share with me if that's possible an...
Discusses William Optics equipment accessories and troubleshooting.
Mar 15, 2023
