RICHARD BREKNE avatar
Ran into this a few days ago and wondered if this would be useable for EQ6r and/or AM5 mounts ? If so do you then run the mount unguided ?
https://ccdware.com/pempro_overview/
I'd say save $150.00 and use the free tools that are already available. I don't see that the software is offering anything new or ground breaking. This software might improve your results slightly but you have to keep in mind that not all drive errors are perfectly periodic. It certainly won't make it possible to do away with guiding to any great degree.
Dale Penkala avatar
This software creates a pec curve that you play back for better tracking. In every case that I’ve used it, (4 times, 2 AP1200’s CGE Pro “OnStep Converted” & CGX) the guiding is better with it off at least in the case with the 4 mounts above mentioned.
I’ve talked multiple times with Ray Graylak about his software and in most cases people use it to get better tracking without guiding. That still doesn’t mean you can’t guide using it in playing it back. You’ll have to play with the settings.
But again in my experience I’ve always had better luck with my AP mounts to not play the pec back and just let PHD2 guide. Many on the PemPro forum have said that as well.
Dale Penkala:
That's been my experience as well, better guiding without PEC.
Lynn K avatar
I have used it with two of my AP mounts. I thought the PEC was improved in both cases.  In fact, I know it was because playback using PEC showed lower periodic error.   All AP mounts have PEC correction applied to new mounts  using PemPro.  No, you do not want to guide while measuring with PemPro. Guiding corrections will corrupt the data. You need to do at lease 20 iterations and average.  Polar alignment will not effect the data, because it is not measured.
 If your mount's PEC is low, PEC may not be needed and guide corrections may be adequate.   If you are using  guiding corrections  ever 1 min or so, PEC will be useless.  That is because such short guiding correction intervals interfer/ over ride the PEC anyway.
Also, scopes of of about 500 to 1000 focal length needs to be used in order to get good measurements.  Smaller pixels will accommodate shorter scopes. Your main camera is used, not your guide camera. I used 3.67 pix with 819 fl. The star magnitude is crutial to good measurement.
PEC is useful when using longer guide corrections intervals such as 7 to 10 min. I use 5min correction intervals and use PEC. I use it with a Mach1 and 600E. PEC can change over a year with a mount that is used regularly. At that point, I did not have PemPro and turned PEC off. I didn't notice much difference in guiding. However, the Mach1 has a PEC error of 2.1 arc  sec,  and the 600E is 1.7 arc sec. So those mounts can be easily auto guided.
PEC can be useful with mounts that have bad spikes in the periodic error. Auto guiding can have trouble overcoming such spikes.
It can help with precisely polar aligned mounts using short exposures, and no auto guiding. I'm not sure if it can be applied to strain wave mounts with high PEC.
Lynn K.
Brian Valente avatar
Breaking it down into three separate responses:
1. If you can use Periodic Error Correction PEC with your mount, imo PEMPro is the gold standard. PEMPro averages multiple cycles to eliminate noise and other non-period errors to create the highest fidelity PE correction. Mounts vary on their PEC implementation, so ymmv regarding using PEC in general, but if your mount has effective PEC, this is the way to go.
2. PEC and guiding are related but independent. PEC will correct for mount's periodic error, but that's not really what guiding corrects for. Guiding will correct for polar misalignment, refraction, flexure, and just about anything else that can contribute to poor star shape/elongation. PEC can improve your guiding, especially if it corrects faster periods. (again, depends on your mount's PEC implementation: some lower end mounts are not able to use PEC and guide at the same time)
3. Regarding the specific mounts you mentioned, EQ6R can benefit from PEC. AM5 as a strainwave mount doesn't really have consistent periodic error, so doing any sort of PEC isn't possible
Helpful Insightful Engaging
Joe Bauman avatar
I tried my old PemPro2 last night for the first time, getting only partial curves because I had forgotten to balance the telescope. Anyway, when I tried to pull up the curves, the forms were blank. What did I do wrong? Or is that the case whenever a cycle isn’t complete? Thanks, Joe Bauman
Read noise Astrophotography avatar
I’ve spent a lot of time guiding both worm-driven mounts (like the EQ6-R) and looking into the newer strain-wave designs (like the AM5). Since guiding questions come up constantly, here’s a proper breakdown of what’s going on mechanically, what PEC/PEMPro can and can’t do, and how to tune guiding for each mount type.
What is Periodic Error?
On a worm-gear mount like the EQ6-R, the worm takes about 7.5 minutes to complete one rotation. Any machining error, eccentricity, or uneven gear mesh introduces a repeatable tracking error over that cycle. It shows up as stars drifting back and forth in RA in a sinusoidal pattern.
Factory EQ6-R mounts usually ship with ±10–20 arcseconds of periodic error. Premium worm mounts can be under ±5 arcseconds.
Periodic Error Correction (PEC)
PEC records several worm cycles, then plays back the inverse of the error curve each time the worm rotates. On the EQ6-R it’s called Permanent PEC (PPEC) because the curve is saved in firmware until you retrain it. A good PEC run can cut periodic error by 50% or more, reducing the guider’s workload.
Where PEMPro Fits In
PEMPro takes this further by:
  • Recording multiple worm cycles with your guide camera.
  • Averaging them to filter out seeing and random noise.
  • Modeling the actual mechanical error.
  • Uploading a smoothed, high-fidelity curve into the mount.
Compared to in-mount PEC training, PEMPro produces much cleaner and more effective curves with fine control.
EQ6-R Guiding Strategy
  • Worm period: ~478–480 s, with secondary harmonics ~120 s.
  • PEC options: Either (A) train PPEC with PEMPro and use low-aggression guiding, or (B) disable mount PEC and let PHD2’s Predictive PEC handle it. Don’t run both strongly at the same time or they’ll fight.
  • Exposures: 1.5–2.5 s to average out seeing without missing the worm cycle.
  • RA settings: With PPEC on > Hysteresis ~35–45% aggression. With PEC off > Predictive PEC ~50–65% aggression and let it learn the cycle.
  • DEC settings: If backlash is small, Auto ~35–50% aggression. If backlash is bad, guide one direction only (north or south) and bias polar alignment so drift stays consistent.
  • Min-move: Start RA ~0.25″, DEC ~0.30″, refine with Guiding Assistant.
AM5 and Harmonic Drives
Strain-wave mounts like the AM5 use a harmonic gearbox instead of a worm. They’re compact and backlash-free, but the tracking error is more complex:
  • A low-frequency, semi-repeatable component (~3–5″).
  • High-frequency gearbox ripple at tens of Hz, which is semi-random.
That high-frequency noise is the killer: PEC can’t predict it, and guiding can only partly keep up. The net result is that PEC has limited benefit compared to a worm mount.
Guiding strategy for AM5:
  • Exposures: short, ~0.5–1.0 s, to catch mid-frequency drift before stars smear.
  • RA: Hysteresis or Predictive PEC with low aggression (30–45%). Raise min-move if you see fast RA oscillation.
  • DEC: Auto, 25–40% aggression. Backlash is almost nil, but overshoot is common if you push too hard.
  • Min-move: ~0.30″ RA, 0.35–0.45″ DEC, then tune from logs.
I am sure stainwave and Active optics (e.g. Starlight Xpress AO) is a killer combo, since they correct at 5–10 Hz, but they eat 30–40 mm of backfocus. Ive never owned a strainwave but I do own active optics..
PEC and Guiding Together
PEC and guiding complement each other, but you have to balance them:
  • If you run a strong PEC curve and aggressive guiding, the two can clash showing up as RA ping-pong.
  • Better approach: let PEC carry most of the worm error, then lower RA guiding aggression so it only catches drift and residuals.
  • This works best with very accurate polar alignment (sub-arcminute) so DEC corrections stay minimal.
    Don’t Forget the Role of Stacking
When you look at guiding graphs, remember that stacking software aligns on star centroids. A lot of the small-scale, high-frequency error never makes it into the final image because pixel rejection tosses it out. Unless guiding is really poor, the stacked result won’t show every wiggle your guider reported.
Still, smoother guiding = fewer outliers, more usable subs, tighter stars, and less reliance on rejection.
Balancing and Backlash Offset
One of the biggest tricks with worm mounts is deliberate imbalance. If you balance perfectly, the gears can float inside the backlash zone, causing oscillation or runaway corrections.
  • In RA: always bias east so the worm is pushing uphill.
  • In DEC: bias so the load always falls one way, then guide north-only or south-only if needed.
This preloads the gears, removes oscillation, and gives the guider a stable system to work with.
Real-World Results
With tight polar alignment, slight off-balance, good PEC strategy, and tuned guiding, I see repeatable all-night RMS between 0.34″ and 0.19″ depending on seeing. That’s well below critical sampling for most setups. I don’t lose subs, and I can comfortably run exposures up to 3600 seconds. At that point, my camera not guiding becomes the limiting factor.
Complete Picture
  • Correct min-move keeps guiding smooth.
  • Deliberate off-balance preloads the gear train and prevents oscillation.
  • Sub-arcminute polar alignment reduces DEC intervention.
  • Stacking software does the final cleanup.
Where did the time 1.5 hours to write that up lol hope it helps!!
Clear skies !!
