There's no real reason to change max guide pulse. If for some reason you need more movement, up your guide speeds. (PHD is actually pretty good at adapting to this without recalibration) Currently I run 0.5x on RA and 0.9x on dec for my EQ6R Pro. PHD doesn't like this when it calibrates because it thinks both should be the same speed, but its of zero consequence. There are reasons specific to this mount for why I run those guide speeds, but I wont dive into that here. I run typically 1 second updates, but if seeing gets bad, I'll slow it down to 2 seconds, rarely higher, any worse than that, I'll just park the scope because I don't want that quality of data. EQ6 needs mount PEC to be trained if you want to guide at those slower speeds, IMO.
If the wind is pushing you off by more than your image scale, I'd probably say you should park the scope instead of trying to image through it. The data will be horrible. If it's just the occasional gust, then I would not change your settings to accommodate it. Cull the sub and move on. As for 'correcting faster', this is also a reason why I choose faster updates. If you run 3 second updates, you get one, potentially major correction every 3 seconds. With 1-2 second, I can get alot more, smaller corrections in time. Now keep in mind, these are all still fully dependent on seeing conditions. If you have wind, AND bad seeing, I'd park the scope.
Just to echo previous comments, comparing anything to the harmonics is apples and oranges. Their periodic error is so high that they cannot perform without guiding at all, save for extremely wide imaging scales.
