Francesco Ottonello avatar
I own a Asiair Pro and a Asiair Mini.
Normally I connect filter wheel and guide camera to the hub of a Asi 183MMpro, then the camera to the Asiair; I connect EAF and my mount to Asiair and the last usb port normally is used with a flash usb.
As I am waiting for Zwo CAA I will lack a usb port for usb flash.
Is it possibile to use an external usb hub with Asiair? If yes it should be powered with external source or is it enough through usb?
Peter Rattfält avatar
Yes it works perfect.
Bob McInteer avatar
I used an unpowered hub for a while, but found the entire system became more flakey. I'm thinking the power available for all the USB connection was not enough. I'd definitely go powered hub or not at all.
Concise
Georg N. Nyman avatar
I got my ASIair256G a couple of days ago and tried an external (unpowered) USB hub as well - yes it works, but the stability is not 100% - it sometimes hangs for a while…
Georg
Lorenzo Siciliano avatar
I currently use a usb hub connected to one of the camera usb ports. That way I have a total number of 9 usb ports available, 4 on the asiair and 5 on the camera.
Everything works without any issues.
Ciao
Lorenzo
What is the right USB Hub for me...?
Hi team, I am taking the slow road to expanding my setup and am looking at purchasing the ZWO Electronic Focuser. However, my laptop only has 3 USB ports and they are all currently in use when I am shooting because of my: - Skywatcher EQ6-R Pro Mount...
USB hub solution for multiple camera/accessory connections via single laptop cable.
Mar 12, 2023
DSLR question
I connect my Canon 70D DSLR to my ASIAir Mini Mini with a USB cable. And it works fine. But I notice theres a small plug in hole on the mini labelled DSLR, and I wonder what thats for. Thx for reading.
ASIAir Mini USB hub connectivity and device connection methods.
Sep 13, 2023
Controlling a UMi 17X: MiniPC or StellarMate/StellaVita/ASIAIR
Hi there! I’m decided to pair my Sky-Watcher Wave 150i with my C8 EdgeHD for Galaxy Season. For this I ditched the AVX mount head, got a ZWO Pier Extension which fits the AVX Tripod and voila: one sturdy, big and not so mobile setup (new guide scope ...
Discusses ASIAIR control options and equipment connectivity setup.
27 days ago
