Askar 71F back focus
5 replies142 views
Damien Galanaud avatar
Hello
I am the happy owner of an Askar 71F that I bought to send to Starfront observatories together with my old AM5, a ZWO off axis guider, filter wheel and 2600 MM Pro. I also ordered a ZWO CAA but I don't know when I will receive it due to the massive delays they seem to have with this equipment. So I will probably end up sending my rig in its current configuration and send the CAA later to Sarfront as soon as I receive it. My question is as follows: my current setup is around 55 mm back focus but when I will add the CAA, it will bring it to over 70 mm. I have enough travel space on the focuser to reach focus, but could it degrade the quality of the images ? I know it is a Petzval design, but the reviews I saw were all performed at around 55 mm. Did any of you ever tested it well beyond the 55 mm classical sweet spot ?
Best
Damien
The tube is out by 37 mm so if I add 16.5 mm to the light path, there will be around 20 mm  left, so this will not be a problem.
Thanks !
First Telescope – ASKAR 71F | Any good resources on how to use it?
Hi everyone, I’ve just bought my first telescope, the ASKAR 71F, and I’m really excited to start my astrophotography journey. I’ve done some photography before, but this is my first proper telescope setup, so I’m very much in learning mode. If anyone...
Author owns ASKAR 71F and seeks guidance on setup and usage configuration.
29 days ago
Pegasus Astro Indigo OAG with Helical Focuser - Looking for Feedback from Owners
Hi all, If you are a user of the Pegasus Astro Indigo OAG with Helical Focuser, I have a question for you. I recently purchased this piece of equipment. It arrived in an old, dirty box without any foam. The OAG was in a small ziplock-style bag just l...
Author uses off-axis guider; feedback on OAG equipment directly relevant to setup.
20 days ago
